Old 24-05-12, 09:08 PM   #1
muzikill
muzikill's Avatar
Default Wemoto sump bolt washer?
Im doing a oil change over the weekend and the washers sent by wemoto dont look very crushable .....
http://www.wemoto.com/bikes/suzuki/s...n_ally_washer/
What do you think?
Old 24-05-12, 09:14 PM   #2
jambo
jambo's Avatar
Default Re: Wemoto sump bolt washer
It's a washer. I'd be completely confident it would seal. The ones for most Kawasakis look like that...
Old 24-05-12, 09:23 PM   #3
tigersaw
tigersaw's Avatar
Default Re: Wemoto sump bolt washer?
It's ally and works fine. My ER6 ones looked like that
Old 24-05-12, 09:23 PM   #4
It's soft aluminium, it'll be fine.
Old 24-05-12, 09:55 PM   #5
muzikill
muzikill's Avatar
Ta. Didnt want any time wasted doing the job. Cheers for the replies.
Sent from my GT-I9100 using Tapatalk 2
New HiFlo oil filter, sump bolt + washer k-man For Sale - SV's and SV related items 0 18-04-10 10:21 AM
oil sump washer steveg SV Talk, Tuning & Tweaking 7 12-10-09 11:55 AM
Sump washer TightRS SV Talk, Tuning & Tweaking 3 18-04-09 09:56 PM
oil sump bolt washer lukemillar SV Talk, Tuning & Tweaking 8 13-09-06 10:22 PM
Sump washer The Mass SV Talk, Tuning & Tweaking 14 27-06-06 09:53 AM
