Old 26-05-12, 06:01 AM   #1
dave_mito
Default Pointy regulator fit Curvy? Again
does any one know if a pointy reg/rec will fit a curvy
thanks
Old 26-05-12, 12:17 PM   #2
mister c
mister c's Avatar
Default Re: Pointy regulator fit Curvy? Again
Yes, but you will have to do some rewiring. Not a very good picture, but this is how I did mine.
Old 27-05-12, 08:12 AM   #3
AlexW
I searched this forum recently for this question. I've now done it, however I ran another peice of twin core wire from the 4pin plug on the pointy to the battery, as I didnt like putting 4 thick wires onto 2 not very thick wires.
Old 27-05-12, 08:34 AM   #4
dave_mito
thanks for the reply, I did try searching but as it only had 10 min left on ebay I needed a quick answer.
so it looks like you just cut the plug of and swap them for the curvy plugs ?
Old 27-05-12, 08:45 AM   #5
mister c
mister c's Avatar
Basically, yes. The 3 similar coloured wires match with the yellow curvy wires from the alternator, then I think it was the 2 black & white, go to single black & white on curvy, then red & black to red & black.
Been a while since I did mine
Curvy regulator Dickyholdsworth Stuff Wanted 1 23-03-10 04:56 PM
regulator/rectifier same for curvy and pointy? tobie14 SV Talk, Tuning & Tweaking 4 25-01-10 03:27 PM
Pointy/Curvy regulator swap? Neeja SV Talk, Tuning & Tweaking 1 28-09-09 10:42 AM
Pointy Regulator on a curvy mister c SV Talk, Tuning & Tweaking 2 15-07-09 07:44 AM
Curvy SV Regulator Rectifier Dave20046 Stuff Wanted 0 12-04-09 04:25 PM
