Old 28-05-12, 12:24 PM   #1
JimmP
Default How much power does a trickle charger use?
How much power does an optimate charger use? Assuming i run it every night for 8 hours. I presume it's not much but my landlady is concerned about power usage as i want to connect it to a communal socket.
Old 28-05-12, 12:46 PM   #2
flymo
flymo's Avatar
Default Re: Trickle Charger
I'll measure for you tonight.
Old 28-05-12, 09:12 PM   #3
MadGaz
Default Re: How much power does a trickle charger use?
Depends on the state of the battery I imagine, if you've been out for a good ride then it wont need to put much of a charge in and will only be putting a tiny current in to stop the discharge. Talking a few pound a month tops.
Old 28-05-12, 09:39 PM   #4
Fallout
Fallout's Avatar
Say it's a 100amp/h battery. 100amp x 12v = 1200 watts. 1kw/h = 16p on an average tariff? So it costs about 20p maybe to fully charge an empty battery. All very rough maths. Think I've got that maths right.
While you're trickle charging, it is charger dependent. Maybe it trickles at 500mahs. 0.5 x 12 = 6watts (0.12 pence per hour). 3p per day!
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Solar trickle chargers - opinions? TC3 Bikes - Talk & Issues 5 21-08-10 06:53 PM
Trickle Charger Advice tonyburrell SV Talk, Tuning & Tweaking 2 18-04-10 06:09 PM
Solar power battery charger ThEGr33k Bikes - Talk & Issues 21 22-02-09 11:17 AM
Solar Powered trickle charger fatneck Bikes - Talk & Issues 14 26-11-08 01:10 PM
Connecting a trickle charger to my SV.. StreetHawk Bikes - Talk & Issues 13 04-04-07 09:38 PM
