Old 01-06-12, 07:06 PM   #1
pookie
pookie's Avatar
Default Help diagnose problem with my smoking zx6r
after finally getting the bike taxed it all went a bit downhill. Firstly battery was dead. When partially charged I went to start the bike and it would turn over but not start.
Left the battery to fully charge.
Went to start the bike which turned and turned and turned some more. Just then it came alive. Unfortunately it started smoking quite heavily. Bear in mind it had its mot end of jan 2012. Started up march I think. and then til now.
The smoke dissapated and I shut the bike down. It had oil at the right level and coolant before i started it. Its done 8.5k and only 2.5 was in the last 2 years so not been ridden much. Typically had it booked in the dealers today for a rocker gasket recall work as it was weeping (common on 2007 bikes which they change when oil starts to leak). Could it be more serious. Have I knackerd it? Any help gratefully received. Cheers.
Old 01-06-12, 07:21 PM   #2
Default Re: Help diagnose problem with my smoking zx6r
ermmm that's condensation.
Old 01-06-12, 07:24 PM   #3
pookie
pookie's Avatar
i really hoped so but it comes on later and is grey and puffs out. The engine temp is 59deg and has been like that for the last three times i ran the engine
Old 01-06-12, 08:34 PM   #4
Bluefish
nothing wrong there, in the vid that is, take it for a ride.
Old 01-06-12, 08:45 PM   #5
pookie
pookie's Avatar
will do...been fannying about all day and its moved in and out of the garage ..thanks for the reassurance bibio and bluefish. will give it a go and try and get rid of the cobwebs.
Old 02-06-12, 06:49 AM   #6
Engine temp of 59 degrees is much too cold to burn away condensation - unless you're going to run it 'til it's hot don't start it.
Old 02-06-12, 08:50 AM   #7
pookie
pookie's Avatar
thank you all very much..the plum of the year award goes to ME
The moral of the story is ride more and often
Old 02-06-12, 05:27 PM   #8
That ain't smoke, this is smoke
YouTube Video
Diagnose this problem: northwind SV Talk, Tuning & Tweaking 16 16-04-06 07:44 PM
