Old 01-06-12, 08:07 PM   #1
frankie77
Default Clutch drag? Wheel spins when clutch pulled in.
hi, ive just done a handle bar conversion, trying to adjust the clutch cable but cant stop the rear wheel spinning with the clutch lever pulled in. any ideas?
Old 01-06-12, 08:21 PM   #2
DJ123
DJ123's Avatar
Default Re: ahhhhhhh
iirc it will spin clutch pulled in or not. why is it a problem?
BMW F800ST
Old 01-06-12, 08:32 PM   #3
Do you mean that it won't stop with the engine running?
Mine won't do this when its on the stand, but when the wheel is on the ground, clutch works as normal
Have you set the worm drive screw properly? Check the worm drive mechanism behind the sprocket cover is moving when you're pulling the clutch lever
Old 01-06-12, 08:36 PM   #4
frankie77
That's interesting that it won't stop when on a stand. I was more concerned about this than setting the rest of the adjustments
Old 02-06-12, 03:43 PM   #5
frankie77
Default Re: Clutch drag? Wheel spins when clutch pulled in.
Well that's better, its all as normal when the bike is on 2 wheels, just to check the next thing, when the bike is started should you still hear a faint sound like the initial fuel pump prime sound?
In gear, ignition on clucth out, should the pump prime on not? Thinking not when its in gear
Old 02-06-12, 03:54 PM   #6
It should prime, but you shouldn't be able to start it.
That's fine then.
Old 02-06-12, 06:46 PM   #7
DJ123
DJ123's Avatar
no, it won't prime unless clutch is pulled in or the bike is in neutral
BMW F800ST
Clutch Drag. StitchSV SV Talk, Tuning & Tweaking 9 28-03-12 06:34 PM
Clutch drag. bengodden SV Talk, Tuning & Tweaking 4 08-01-11 12:21 AM
Clutch drag. vtwinthunder SV Talk, Tuning & Tweaking 8 10-09-10 11:52 AM
clutch drag - how much it to much barwel1992 SV Talk, Tuning & Tweaking 3 04-06-10 06:06 PM
Cut out when clutch pulled in andyb SV Talk, Tuning & Tweaking 11 06-03-07 01:19 PM
