hi all, does anyone know if an ijected motor will fit into a curvy frame, then fitted with carbs, tar all rob
Yep that's what I'm running. 07 engine in 01frame
Yep, you'll need to :-
Blank off the clean air then swap rocker covers Swap generator and pickup Swap gear position/neutral switch The oil cooler doesn't fit with a few exhaust systems, if you blank it off (Yamaha sump plugs ![]() Swap thermostat housing (from memory) as temp switch is different and stat diff temp. Oh and an M4 system won't fit as sump is deeper and it fouls on cooler blanks so def can't run cooler. |
ok, all sounds ok so far,,would carby exuast header pipes fit .we run standard header pipes,???
yes, injected headers dont fit very well (limited ground clearence) you just need to change the rear exhaust stub for the carby one
I'm Running hindle headers and theirs fit either curvy or pointy as the engine dimensions are the same at the point where the exhaust connects (just uses different link pipe. I have also got standard 2006 headers and renegade headers that all fit comfortably. Ground clearance isn't an issue as I'm also running race fairings.
Gladius motor in Curvy frame? | jonneyflame | SV Talk, Tuning & Tweaking | 1 | 22-01-12 02:12 AM |
Curvy Starter motor | arcdef | Stuff Wanted | 6 | 29-01-11 02:22 AM |
Wanted curvy starter motor | mouse8197 | Stuff Wanted | 3 | 30-05-10 06:51 PM |
Parts For Sale - Curvy and Injected | adjblade | For Sale - SV's and SV related items | 7 | 29-03-10 11:21 AM |
For curvy: Starter motor, carbs. | northwind | Stuff Wanted | 7 | 26-11-05 12:18 AM |
