Old 14-06-12, 06:50 PM   #1
Toooldtodie
Toooldtodie's Avatar
Question Speedo/odo reading low
Recently entered SV ownership and have an issue. While its nice to do a 40 mile commute and register 30 miles, it does make judging my speed a bit tricky as under-reading speed as well. What could be going on? Local garage cleaned sensor and checked connections but problem persists. Standard in all but a few cosmetic changes. Seriously worried about getting nicked for speeding and then having a CU20 slapped on for non-working speedo if I appealed! Any suggestions appreciated.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am.
05 SV650s now with proper suspension, hurrah!
Toooldtodie is offline   Reply With Quote
Old 14-06-12, 06:55 PM   #2
DJ123
DJ123's Avatar
Default Re: Speedo/odo reading low
is the connector in tact and not broken?
What bike/model do you have?
BMW F800ST
Old 14-06-12, 07:01 PM   #3
Toooldtodie
Appears to be fine. It's an 05.
Thanks for prompt response daddyjob!!
Old 14-06-12, 07:03 PM   #4
Toooldtodie
What a plum I am it's an SV650s!
Old 14-06-12, 07:06 PM   #5
DJ123
DJ123's Avatar
when they checked/ceaned the connector did they remove the magent from the housing to make sure it isn't cracked or damaged?
BMW F800ST
Old 14-06-12, 07:07 PM   #6
Toooldtodie
Bit more detail may help, methinks. At 5500 in 6th reads 47mph. Steady, no random numbers, but wrong.
Old 14-06-12, 07:08 PM   #7
DJ123
DJ123's Avatar
yes, should be at 75mph iirc
BMW F800ST
Old 14-06-12, 07:10 PM   #8
Toooldtodie
OMG. No wonder everyone got out of my way!! Mechanic said it looked ok, but must be something not obvious to naked eye. Better get replacement before replacement licence required!!
Thanks for your help..
Old 14-06-12, 07:14 PM   #9
DJ123
DJ123's Avatar
check it is ok first before moving on. it's a magnetic rotor that sits in a housing. it fits into equally spaced areas in the front wheel. they are easy to break as they are quite brittle (only about £20 i think from Suzuki). check this yourself or someone 1st.
do you trust the garage you took your bike to, are they clued up on the SV/Suzukis'?
BMW F800ST
Old 14-06-12, 07:24 PM   #10
Toooldtodie
They're pretty good and seem more interested in repeat business than making a fortune. He seems pretty well versed in SVs as he originally said he would check all connections from sensor to speedo as he sited this as a common issue. Tyres look pretty new, so maybe a ham-fisted tyre fitter?
Speedo reading double Nick_69 SV Talk, Tuning & Tweaking 7 19-05-11 11:52 AM
Speedo reading erratically. ryansv SV Talk, Tuning & Tweaking 15 04-03-11 06:23 PM
Speedo Over Reading. tonynorman SV Talk, Tuning & Tweaking 12 01-09-10 12:16 AM
Is your speedo reading '0'? Uu Mr.E uU SV Talk, Tuning & Tweaking 14 05-03-10 08:46 AM
speedo over reading steveg SV Talk, Tuning & Tweaking 2 09-09-06 03:09 PM
