Old 19-06-12, 04:03 PM   #1
Cursed
Default Smaller chicken strip at front than rear?
Anyone else had this on their SV?
Was running a pair of Michelin PR3's which had virtually no chicken strip at the front, however a decent 1/2 inch at the rear. Just fitted a brand new pair of Michelin Pilot Power 2CT's and they seem to be going the same way, although I've only ridden them for 100 miles. Both sets standard sizes.
Anyone have a reason for this? I thought it could be the profile of the PR3's but the 2CT's are kinda doing the same.
Its not a massive problem is just a bit concerning when I try to push a little harder that the front may wash out.
Cheers.
Old 19-06-12, 04:05 PM   #2
flymo
flymo's Avatar
Default Re: Smaller chicken strip at front than rear
tyre geometry, pure and simple. Just make sure your pressures are set correctly and she'll be right.
Old 19-06-12, 04:06 PM   #3
NTECUK
NTECUK's Avatar
Smaller type .different profile
Old 19-06-12, 04:08 PM   #4
jambo
jambo's Avatar
Do you brake into bends?
Do you get on the throttle from apex to exit?
Would you say your rear shock or your front forks make you feel more confident?
Old 19-06-12, 04:16 PM   #5
Cursed
Tbh I'm normally not going fast enough on entry so find myself accelerating from the beggining of most corners, however not pinning it obviously. Theres 0.8 K-tech fork internals in the front and they feel good, I'd say the rear feels a bit wibly wobly though.
Old 19-06-12, 04:24 PM   #6
tonyk
tonyk's Avatar
what tyre pressure have you got. i got 36 front 42 rear.
"Meh" - ASM Forever, RIP. 13/03/1986 - 05/04/2008
"Better to keep your mouth shut and appear stupid than to open it and clear all doubts."
Some days its not even worth chewing through the restraints...
tonyk is offline   Reply With Quote
Old 19-06-12, 05:22 PM   #7
Fozzy
What! I've 33 front in my rp3's and 36 rear. That's what the Sv manual says.
Sent from my GT-I9100 using Tapatalk 2
Old 19-06-12, 05:39 PM   #8
flymo
flymo's Avatar
should be 33 front and 36 rear unless otherwise stated by the tyre manufacturer for your specific model.
Old 19-06-12, 08:57 PM   #9
Cursed
Yeah running the stock pressures...
Old 19-06-12, 09:02 PM   #10
GowerSV
Default Re: Smaller chicken strip at front than rear?
Yep exactly the same for me on my 2011 on stock D220's. I wonder if screwing down the front shocks to max will help. I'm 6' and 14stone. Standard tyre pressure. I just assumed this was the situation with the SV. My other bike, DL650 has slightly wider front strips. I also wonder if riding position affects this - I am usually hard against the tank.
Front brakes, strip + rebuild, replace or upgrade? 7755matt SV Talk, Tuning & Tweaking 6 20-12-09 08:22 AM
Smaller front sprocket tomjones2 Bikes - Talk & Issues 1 15-11-07 12:03 PM
Rear wheel strip down andyb SV Talk, Tuning & Tweaking 2 03-05-06 01:04 PM
Hugger, Fender Extender and Smaller Front Indicators? aimhamilton SV Talk, Tuning & Tweaking 2 30-08-05 07:41 PM
Smaller rear brake disc and caliper.... anyone? Vtwinlover SV Talk, Tuning & Tweaking 2 17-07-05 07:28 PM
