Old 07-07-12, 02:32 PM   #1
gibsdsid
Exclamation SV650 03 Indicator problem
Hey, I've recently bought a 2003 SV650 which has a recent service and MOT
all is well except the front left indicator doesnt work and the read left blinks at double the rate it's suppose to.
Tryed a new indicator relay but that didnt help. I know the bulbs are fine because I've swapped them over from the indicators that do work and its still the front left that doesnt work
any ideas guys?, cheers!
note: these are just the standard blinkers, not LED's
Old 07-07-12, 02:40 PM   #2
DJ123
DJ123's Avatar
Default Re: SV650 03 Indicator problem
sounds like a wiring issue, the indicator isn't getting any power
BMW F800ST
Old 07-07-12, 02:40 PM   #3
sv_rory
it would either be a faulty bulb, or a connection to it. I would check all the connections are clean and free from rust etc.
Old 07-07-12, 03:04 PM   #4
gibsdsid
I've checked the bulbs, like I said I swapped a bunch around and it was always the front left
I took the front cowling/fairing off for a look at the connections but everything is connected, not really sure what I'm looking for though, I'm more of a mechanical guy, I hate electronics
would I be worth just getting a shop to look at it instead?
Old 07-07-12, 03:15 PM   #5
DJ123
DJ123's Avatar
it's simple and easy. Follow the wiring from the indicator back and make sure all connectors are tight and the wire isn't shorting out any where
BMW F800ST
Old 07-07-12, 03:31 PM   #6
sv_rory
put an earth to the frame somewhere and push it into the connector for the indicator, will tell you if it is an earth wire. It might even be the bulb holder inside the indicator
Old 08-07-12, 05:11 AM   #7
madnlooney
check where the wire connects to the metal bulb holder. mine broke on the connector and the indicator would work when i bent the unit as the wire would touch then stopped when i let go. just need to stip the wire and reconnect / solder it
Old 08-07-12, 06:07 AM   #8
FG1
Undo the connectors to both the front indicators. Swap them round and see if the right hand indicator stops working. If it does, then it's the wiring. If it doesn't then it's the indicator unit.
Old 08-07-12, 10:57 AM   #9
gibsdsid
thats a good idea, cheers FG1, I'll do that as soon at the sun comes back out
LED indicator relay problem. DJFridge SV Talk, Tuning & Tweaking 37 16-09-13 05:35 PM
Indicator problem. gabrielkeown SV Talk, Tuning & Tweaking 8 29-07-10 08:54 PM
07 bandit indicator problem. scottjames Bikes - Talk & Issues 5 28-12-09 01:47 PM
Indicator problem blackrat SV Talk, Tuning & Tweaking 6 08-09-08 05:28 PM
Indicator Problem Side MS SV Talk, Tuning & Tweaking 23 26-05-08 07:11 PM
