Old 08-07-12, 08:58 AM   #1
arsenaldeb
Default Pannier rails for Pointy.
morning all
does anyone have or know where i can get pannier rails to fit my 2009 pointy?
Thank you
Old 08-07-12, 09:25 AM   #2
rictus01
rictus01's Avatar
Default Re: Pannier rails
generally pannier rails aren't used on the SV as the sidepods are robust enough for soft panniers, however I have fitted a givi set and hard cases, the system comes in three parts, the first is rails, the second is the base plate (rack) and the third is the pannier rails, the only problem was the pannier rails couldn't be fitted alone as they mounted on therack supports , the end result was a 48ltr topbox and two 36ltr panniers, this was all on a 2007 Sv650s, as far as I'm aware the bodywork is the same, but you'd have to check.
Cheers Mark.
Old 08-07-12, 10:26 AM   #3
stormingjoe
stormingjoe's Avatar
They are getting rare, you could try SW motech, they used to do a kit, which took most popular boxes, Givi did a rail kit, but are no longer manufactured. PL529 was the part number, only fits to a monorack so you will need one of those as well!!
stormingjoe is offline   Reply With Quote
Old 09-07-12, 03:57 PM   #4
rictus01
rictus01's Avatar
these would work I suspect
http://www.hepcoandbecker.co.uk/sw-m...5mpb1v5ji5is04
Cheers Mark.
Old 24-02-13, 10:38 AM   #5
Sid
I was looking for some as well. No joy finding UK suppliers on the net. There were some on europe ebay from Spain. But i managed to source the rack for the topbox easily and then managed to find a UK seller selling the pannier rack for an SV1000 which fitted after i got a second hand left footpeg assembly...Bikes now got a V52 topbox and V42 Keyless panniers on. Looking really good and loads of storage.
Old 25-02-13, 04:27 PM   #6
Sid
Default Re: Pannier rails for Pointy.
All put together and luggage attached. Very strong and stirdy.
Givi top box rack and pannier rack (pointy) aliwakeskate For Sale - SV's and SV related items 0 02-09-12 12:03 PM
Mk1 1200 bandit grab rails Geodude Stuff Wanted 0 13-05-10 06:53 PM
De-rails -Ralph- Idle Banter 12 30-04-09 11:17 PM
Crash.NET - Hopkins: I'm on rails! NewsBot News 0 04-05-07 11:40 AM
Now cornering like I am on rails... Shooter Bikes - Talk & Issues 6 10-04-05 12:29 PM
