Hi,
Im stuck at work, my bike will not start. The sidelights work and so do the indicators. I turned the key and the dash worked for a second and now it is dead, the injectors dont make a noise and the headlight and brake lights dont work. Any clues? I don't have tools or spare fuses. Going to try get a lift home for tools and such. |
Battery totally flat?
Blown main fuse or ignition fuse? Good luck and hope that you get it fixed. Where are you based, if you are close to me I may be able to help with a lift |
Bikes not in gear is it? I have done that once before :/
#4 | |
Thanks for offer, but im up north. Got a lift making the hours journey now. My bike doesn't have a tool kit. Ill have to sort that after today. |
Have you tried bump starting it? ... mght give the battery a little "humph" to kick into life :/
first port of call is the three cut outs, clutch/gear and kill switch, then battery voltage, then main relay and fuses.
But on the info given beyond that is currently a shot in the dark. Cheers Mark.
Tried bumping it. seems to be tiring me and leaving my tyre in the car park. Least it is indoors from the rain while I wait.
#9 |
If dash is completely dead than it won't be kill switch or sidestand/clutch interlock. Either the battery is dead, one of the battery or solenoid connections is corroded or loose, or the main fuse is blown/corroded etc, or the ignition switch is knackered or one of the connectors between ignition switch and main relay is dead.
#10 |
turn ignition on and wiggle the wires that come out of the right hand side of the frame see what happens.
Bored and stuck in work | appollo1 | SV Ecosse | 6 | 29-06-12 01:11 PM |
Battery always dead! I have tried everything! please help sv650.org | andyfordceo | SV Talk, Tuning & Tweaking | 21 | 01-09-09 03:15 PM |
SV650 Sport Dead Battery | SV650YoungRider | SV Talk, Tuning & Tweaking | 20 | 18-10-08 04:51 PM |
Dead Sv650 | k146 | SV Talk, Tuning & Tweaking | 12 | 23-09-07 02:25 PM |
Is my battery dead or are gremlins at work? | Peetee650 | SV Talk, Tuning & Tweaking | 6 | 17-05-07 09:24 PM |
