For Sale - SV's and SV related items For SV's and SV spare parts only. 650 or 1000 No other items Unsanctioned trade ads will be deleted as will spam and chat. |
I'm selling these silver riser plates - a cheaper alternative to rearsets or as a lowering kit - moves pegs 1" back and 1" up or down:
http://www.ebay.co.uk/itm/Riser-Plat...#ht_1319wt_808 Which have been fitted to an SV1000SK3 so slightly marked but cosmetic only. Will fit 1999 - 2011 SV650N/S and 2003 - 2008 SV1000N/S. PLATES ARE REVERSIBLE (1-INCH BACK & DOWN) ON 1999-2002 SV650's. THE PLATES WILL REQUIRE SOME GRINDING TO MAKE THEM REVERSIBLE ON THE NEWER 2003+ SV650's & 1000's BUT IT IS POSSIBLE - see the thread http://www.sv-portal.com/forums/showthread.php?t=43190 which details the mods; essentially mod the brake lever and stop switch springs, brake reservoir to cylinder pipe and the gear change rose joint needs reversing. I'm in Gloucester. Last edited by tim8061; 13-07-12 at 03:43 PM. |
I'm interested in them, can you post? I assume they'd fit in a normal envelope?
I can't see the pictures that need doing to reverse them for a 2003 model without registering, do that in a sec Last edited by quik_d; 13-07-12 at 09:08 PM. |
SOLD! You're first - will PM you, cheers
hi mate
i know you have sold these now, but can you tell me when fitting do you need to change anything else on the bike or is it an easy fit? |
Curvey riser plates | bigchris | For Sale - SV's and SV related items | 2 | 01-05-12 06:55 AM |
Curvy rear set riser plates | LJH | Stuff Wanted | 0 | 11-04-12 11:42 PM |
Riser plates | nomski | SV Talk, Tuning & Tweaking | 1 | 29-08-11 04:39 PM |
Curvy rear set riser plates | Winder | Stuff Wanted | 10 | 07-05-11 03:37 PM |
Footrest riser plates - where from? | danf1234 | SV Talk, Tuning & Tweaking | 12 | 17-08-10 02:09 PM |
