27-07-12, 09:36 PM | #1 |
Gear shifter fell off - Pointy.
Turned at a junction and went for 2nd....huh?...no gear shifter well it was there just a moment ago! Pulled in to the side and saw the whole assembly was hanging loose. Only 1/2 a mile from home luckily so rode slowly in 1st. Right let's have a good look....ah bolt 33 has come out.
I dropped the bike in the garage a while back and the shifter took the weight - must have worked it loose a bit and over time it has come right out. Took off ring 38 and slid out the lever allowing me to tighten the bolt. Popped back the ring and 'bingo' the shifter changes nicely now - I thought it had been a bit notchy! Gives you a bit of a scare mind when you go to change and there is nothing there! Could have been worse and happened miles from home - or even worse, when overtaking |
27-07-12, 09:47 PM | #2 |
Re: Gear shifter suddenly not there!
Happened to me once. Make zip/cable ties your best friend. I always carry a pack for moments like these.
27-07-12, 10:52 PM | #3 |
Happened to me and a bunch of people about 6 years ago - K6's seemed particularly prone.
Sent from my PC NOT using any Tapatalk type rubbish!! █╬╬╬╬(•)i¯i▀▀▀▀▀█Ξ███████████████████████████████) |
27-07-12, 11:10 PM | #4 |
so no weekly checks then I take it
28-07-12, 06:47 AM | #5 |
28-07-12, 07:54 AM | #6 |
seriously ? you don't ride for more than 15 minutes a week?
28-07-12, 08:46 AM | #7 |
Suzuki factory worker forgot to threadlock and torque these on a shift?
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ), drop it & fix it again! K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
28-07-12, 09:31 AM | #8 |
About 15 hours per week. Seriously, I wonder how many SV riders check their shift torque more than a couple of times a year? Tyres, brakes, oil, chain etc but nuts and bolts...I wonder how often the guys on here do those?
28-07-12, 09:32 AM | #9 |
Re: Gear shifter fell off - Pointy.
28-07-12, 01:36 PM | #10 |
frankly I'm surprised it undone so much as the fall off without you noticing although you did say it felt notchy, but still didn't check, if you ignore the bike giving you signs something is wrong, then you're going to have an eventful time with it.
Gear shifter spindle | Fozzy | SV Talk, Tuning & Tweaking | 9 | 26-06-12 02:04 PM |
Desperaley need a k6 gear shifter | joshwalker094 | Stuff Wanted | 15 | 19-12-11 09:38 AM |
Curvy gear shifter | JamesMio | Stuff Wanted | 3 | 28-02-11 05:21 PM |
Goodby Gear shifter :( | hob | SV Talk, Tuning & Tweaking | 7 | 18-11-08 05:29 PM |
Gear shifter linkage rod | Razor | SV Talk, Tuning & Tweaking | 5 | 05-01-07 11:26 PM |
