Old 28-07-12, 08:12 AM   #1
phil24_7
Default Pointy Pyramid undertray - Candy Grand Blue/YC2
£50 Plus delivery SOLD
This is brand new and has never been fitted. It was originally marked up at £129.99 but was bought in a sale for £99.99.
It comes with fitting instructions, comes in its original packaging and is in perfect condition.
Regards
Old 28-07-12, 08:50 AM   #2
muzikill
muzikill's Avatar
From the looks of it if you dont have a standard tail tidy it might be difficult to fit.
Old 28-07-12, 09:09 AM   #3
phil24_7
Default Re: Pointy Pyramid undertray - Candy Grand Blue/YC2
This replaces the undertray and tail tidy, you just need a bike it/motrax numberplate/indicator bracket which are £5-10 and your away. It also replaces the standart t-section piece that goue between the rear light.
Regards
Old 28-07-12, 09:56 AM   #4
muzikill
muzikill's Avatar
If anyone wants to tidy the back end this is a good option then.
Old 30-07-12, 03:20 PM   #5
phil24_7
Yes indeed. I currently use a different make one on my SV.
Regards
Phil
Old 31-07-12, 02:25 PM   #6
phil24_7
BTT
Old 01-08-12, 08:00 PM   #7
phil24_7
Bump
Old 02-08-12, 08:27 PM   #8
Antrats73
Antrats73's Avatar
Pm'd you mate!!
Antrats73 is offline   Reply With Quote
Old 02-08-12, 09:06 PM   #9
phil24_7
Replied.
Old 05-08-12, 04:55 PM   #10
phil24_7
Bumpity bump.
Wanted: Pointy Seat Cowl (Grand candy blue - YC2) skithepowder Stuff Wanted 0 16-12-10 11:03 PM
Wanted: Pointy SV 650s Candy Grand Blue - Full fairing guywestlake Stuff Wanted 2 26-10-08 08:59 AM
diy... candy grand blue...is it do able stooster SV Talk, Tuning & Tweaking 7 22-07-07 12:55 PM
candy grand curvy undertray Quiff Wichard Stuff Wanted 0 21-03-07 07:09 PM
Pointy SV650S Fairing Lowers, Candy Grand Blue (YC2) Dan For Sale - SV's and SV related items 3 20-02-07 03:56 PM
