Old 31-07-12, 10:30 PM   #1
chubsworth
Default Seat cowl fitment without infills?
Hey guys,
Done a quick search to see if i could find anything but no luck
Been lurking on this forum for a while and decided to join and give
as much input as i can
Found a seat cowl but it doesnt come with infills (surprise surprise)
I want to do away with the grab rail but if there arent infills will i need to
keep the grab rail on to fit the seat cowl?
Thanks for your help.
Old 31-07-12, 10:57 PM   #2
lammypie
Default Re: Seat cowl fitment without infills
You'l be able to fit the cowl without the infills (washers in place of bar) but there will be large gaps in the cowl seating and fairing. If you keep the grap rail ofcourse this wont be a problem.
Old 31-07-12, 10:58 PM   #3
sputnik
If memory serves, the grab rail goes across the bottom of where the cowl or seat would fit and forms a bar that the cowl/seat clips under. I guess therefore that you'd need to either keep the grab rail and live with it, buy infills which are presumably designed to solve this very issue or else cut down the grab rail bar outside of where it bolts on and either leave strange gaps or fashion yourself some sort of mini infill solution yourself.
Depends how much effort you fancy putting in - someone will no doubt have come up with an ingenious solution.... just wait.
Old 31-07-12, 11:02 PM   #4
Runako
I have some black new infils if needed. Let me know.
Old 31-07-12, 11:06 PM   #5
chubsworth
Thanks for the fast replies guys.
Runako, I'll pm you about the infills!
This cowl i found is blue but shouldnt be too hard to spray
Seat cowl infills, Curvy Small Clanger Stuff Wanted 4 20-05-12 07:15 PM
Seat cowl infills - where from? OWhite SV Talk, Tuning & Tweaking 4 23-04-12 10:56 AM
rear seat cowl infills svsam Stuff Wanted 0 22-08-11 06:51 PM
pointy seat cowl infills help. beno987 SV Talk, Tuning & Tweaking 5 23-01-11 08:49 PM
Pointy Seat Cowl with infills rob13 For Sale - SV's and SV related items 10 22-08-08 10:19 PM
