Old 04-08-12, 09:23 PM   #1
650
650's Avatar
Default Brake fluid reservoir rubber?
Evenin'
My brake fluid reservoir has the little rubber insert in it, I've seen quite a few other bikes without it. Is it an important thing to keep?
Also, I'm going to purchase a new chain and sprocket set, what T combination will be best for economy?
Thanks!
650 is offline   Reply With Quote
Old 04-08-12, 09:39 PM   #2
Default Re: Brake fluid reservoir
the little rubber insert is there to stop air getting in as the level drops the insert expands to fill the void. without it the fluid would go off quicker as its open to the outside air which is full of moisture.
Old 05-08-12, 11:29 AM   #3
monkey
As well as possibly absorbing moisture from any air ingress (which could cause spongy brakes) it may leak brake fluid.
Sweatbands around brake fluid reservoir? Fallout Bikes - Talk & Issues 21 10-07-12 08:27 PM
Brake Fluid Reservoir cammy Stuff Wanted 1 30-10-09 08:03 PM
brake fluid reservoir for a curvy S mouldy Stuff Wanted 4 15-03-09 09:49 PM
Tubing Brake Fluid Reservoir DarrenSV650S Bikes - Talk & Issues 23 22-01-09 03:30 PM
Front brake fluid reservoir Sloth Stuff Wanted 1 21-12-05 10:52 AM
