Old 08-08-12, 11:27 AM   #1
BoltonSte
Default Help turning raised deck into woodstore
So, I have a multifuel stove and I have a raised deck in the garden (about 3' off the floor). I did a botch job using ply that was the cellar ceiling when we moved in to keep the worst of the weather off the wood I stored underneath it, but want to make a proper job of it this year.
The deck is on joists and legs, and I'm trying to figure out the best way of waterproofing underneath it, I've looked at off the shelf answers like corolux corrugated PVC to place between the joists, but the widths and lengths I need don't match up, I've also looked at using exterior/marine ply, in the same way, but because of the lengths involved (up to 3m) off the shelf stuff would need to be overlapped.
My current thought is to take all the decking boards up, board the whole thing with exterior ply using those plastic edging strip things (no idea what they are called) and silicon to join sheets (they will be well supported) and stop water dripping through. Then have some spacers (probably from the ply) to go where the boards fasten to the joist so there is still space for the water to run off.
Does this sound reasonable, does anyone have any other ideas?
This
____
to
____
__ __
_____
(Best I could do at the moment)
Ste
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 08-08-12, 04:57 PM   #2
Default Re: Help turning raised deck into woodstore
Exterior ply won't last, it might be water resistant but wont stand up to persistent wet environments.
Id be more inclined to use a black heavy weight DPM, stapled or something to underside of the joists.
But, you will need to make allowances for some water run off or it will just fill up with water.
Old 09-08-12, 09:32 AM   #3
BoltonSte
I was wondering about DPM but didn't know if it would hold on staples...I'll see what I can figure with this...easy to cut to size as well.
Ste
Had an SV or three.
Old 09-08-12, 11:23 AM   #4
keith_d
keith_d's Avatar
Rather than stapling DPM to the joists attach it using wooden battens and galvanised nails. Install with a 1/24 slope so that water runs down to a suitable spot for drainage.
For longer spans fix another batten to the underside of the deck boards in the middle of the span, parallel to the joists.
Old 15-08-12, 01:41 PM   #5
BoltonSte
Been looking into this, all I can find online is 1200 gauge. Is this what you mean by heavy duty or is there somewhere else I should be looking that's more specialised?
Had an SV or three.
Old 15-08-12, 05:11 PM   #6
Screwfix.com have loads...
http://m.screwfix.com/c/building-joi...unknown&_bck=1
Old 15-08-12, 08:04 PM   #7
BoltonSte
I just wasn't sure if 1200 was one mans heavy duty, another mans tissue paper. But looks reet I'll get some sorted.
I am currently a mouse free zone. I had a couple last year so put traps and posion down. I was getting one a day for a week and the poison kept going after that. Even got a rat in the gin trap (I'd seen it walking over the deck). I run sample traps now and again to keep an eye in things. I blame the takeaways across the road, the fields behind, the restaurant at the end of our terrace and the raised bed I had which I found the base wase filled with rocks.
Cheers folks
Had an SV or three.
Old 15-08-12, 08:24 PM   #8
timwilky
timwilky's Avatar
If you do want heavy duty then http://www.cwberry.com/Inquiry_Produ...umber=02190195
Not Grumpy, opinionated.
Crash.NET - Dovizioso, Crutchlow hit the deck after podium challenge NewsBot News 0 20-05-12 07:50 PM
Raised rear end - anyone done this? svdaz SV Talk, Tuning & Tweaking 6 14-04-10 10:46 AM
WTB: raised clip-ons for curvy mnrsmith Stuff Wanted 0 30-03-09 08:35 PM
I know this has been raised before... Gra Idle Banter 49 26-06-08 12:59 PM
raised rear suspension antony SV Talk, Tuning & Tweaking 1 16-05-07 11:50 AM
