Old 12-08-12, 03:43 PM   #1
Thunderace
Default Suspension adjusting tools?
Anyone got a photo of the tool you need to adjust a rear rebound damper?
Old 12-08-12, 03:48 PM   #2
Bordtea
Default Re: Help!
http://www.google.co.uk/imgres?um=1&...,r:0,s:0,i:139
Glad to be of service
Disclaimer: I have absoloutely no idea
Old 12-08-12, 03:57 PM   #3
Thunderace
Default Re: Help!
Belive it or not that actually worked! I had to give it some welly and I dont think my hand will be the same for a while, but it worked!
Old 12-08-12, 04:00 PM   #4
Bordtea
Default Re: Help!
What can I say I'm full of bright ideas
Old 12-08-12, 04:14 PM   #5
Thunderace
Default Re: Help!
It was really loose got it as tight as I could and then got some mole grips on it!
Old 12-08-12, 04:49 PM   #6
BlackFlag94
Default Re: Help!
I believe the correct tool is what I would refer to as a "C" spanner. Also what you use to tighten the chuck on a milling machine
Old 12-08-12, 05:39 PM   #7
Thunderace
Default Re: Help!
C spanner to adjust preload, to adjust rebound it is like a small sprocket on the bottom of the shock, I got some large mole grips on it and its all good now!
Old 12-08-12, 07:11 PM   #8
BlackFlag94
Default Re: Help!
Ah.. sorry my bad. Didn't read correctly
Changing the Rear Suspension (adjusting standard shock) Larry SV Talk, Tuning & Tweaking 18 31-08-09 01:23 PM
Adjusting GSXR suspension, (on an SV). chakraist SV Talk, Tuning & Tweaking 26 09-07-09 03:00 AM
Adjusting Rear Suspension on SV Stoneyginger SV Talk, Tuning & Tweaking 5 27-04-08 06:29 PM
Adjusting suspension on the 06 SVS Kawyamonda SV Talk, Tuning & Tweaking 4 20-02-06 01:01 AM
Adjusting rear suspension Chris1 SV Talk, Tuning & Tweaking 8 22-03-05 12:26 PM
