Old 19-08-12, 07:39 PM   #1
Rbusby
Default Pointy squeaks when accelerating.
My Sv650 is k6.. it's recently developed a intermittent squeak when i accelerate, depending also how much i adjust the throttle.
I suspected that it was my loose chain, but after tightening it, and lubricating it, there is no change..
The bike hasn't been serviced in 6,000+ miles, was wondering if it could be the injectors.
Is there any other possibilities, is it a common thing? :/
cheers
Old 19-08-12, 09:52 PM   #2
DJ123
DJ123's Avatar
Default Re: Pointy squeaks when accelerating.
is the squeak continuous when accelerating, or only when you initially roll on the throttle
BMW F800ST
Old 19-08-12, 10:21 PM   #3
speedyandypandy
bearings, brake disc, can't think of anything else right now, getting tired it's 00.20 over here, soon time for bed.
Old 19-08-12, 11:40 PM   #4
Rbusby
its only initially, once i throttle past a certain point, it stops :/
Old 19-08-12, 11:41 PM   #5
when you say the bike hasn't been serviced in 6k+ miles is that including the oil and filter?
Old 20-08-12, 12:48 AM   #6
Rbusby
i've done oil changes myself, just not the full service
Old 23-08-12, 07:24 PM   #7
drewby89
Are you sure it's not just that you can no longer hear it over the engine? Mine has a similar thing actually, and ive had a look round the front of the bike (which is where mine sounds like its coming from) and there's some rubber coated cables clipped down onto the mudguard, if I wiggle these cables around theres quite a loud squeaking sound and I'm unsure if this is what I'm hearing when I'm riding.
Old 23-08-12, 08:04 PM   #8
Fallout
Fallout's Avatar
Could be the clutch slipping. Would probably be more prevalent when the bike is cold.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 24-08-12, 09:57 AM   #9
jambo
jambo's Avatar
When the bike is stationary, try bouncing the suspension up and down (both ends) and see if you can hear anything out of the ordinary.
The swing arm or suspension linkage bearings might be possible suspects as you'd get a movement there as the bike accelerates abut it then all stays about the same as the speed rises.
Jambo
Bucking...kangaroo bike when accelerating. Traders Bikes - Talk & Issues 13 24-05-11 08:19 PM
Single cylinder when accelerating - in the dry! Al_Sweetman SV Talk, Tuning & Tweaking 16 08-11-10 12:13 PM
lost power - stifling when accelerating ceyn Bikes - Talk & Issues 10 26-08-10 07:39 PM
accelerating rattle Jock Bikes - Talk & Issues 7 14-07-05 09:38 PM
