Old 20-08-12, 05:17 PM   #1
Scratchy081068
Default Flat battery - Curvy.
Hi everyone, went to start my SV 99 yr this morning and after 4 engine turns which it tried to fire it then resulted in nothin, just click every time I turned the key. Any suggestions
Only checks done is the battery and my optimate says green so assuming battery is okay and lights are all on.
Could be rectifier and alternator? Anyone now how I can check which one at fault or any other suggestion,many thanks
Old 20-08-12, 07:08 PM   #2
Thunderace
Default Re: Sv650 no start
Locate your starter solenoid, turn the ignition on, put a screwdriver between the points, if engine turns over the solenoid is duff, shouldn't be too expensive to buy a new one.
BTW you may get a bit of a spark but don't panic just hold the screwdriver, when the engine turns the spark will stop.
Old 20-08-12, 07:11 PM   #3
Geodude
Geodude's Avatar
Get a multimeter and have a check through this http://www.electrosport.com/media/pd...ng-diagram.pdf HTH
Curvy - flat battery. rickyc1 SV Talk, Tuning & Tweaking 8 30-09-12 09:23 PM
Flat Battery? Rob84 SV Talk, Tuning & Tweaking 14 02-03-10 10:37 PM
flat battery jimc SV Talk, Tuning & Tweaking 5 15-01-09 10:32 PM
Help! Flat battery.. Prawn Bikes - Talk & Issues 25 26-11-06 10:42 AM
flat battery-again! ronshaw SV Talk, Tuning & Tweaking 4 02-08-05 08:04 AM
