Old 21-08-12, 10:23 AM   #1
m1tch_1987
Default Carb heaters needed?
Hi all,
I am using an SV650 engine as a race engine rather than a road going engine, I know that I have carb heaters on my early engine but the question is, do I need to keep them?
I am guessing they are just used for cold starts in the winter or are they also used to reduce carb icing when the engine is running?
Old 21-08-12, 11:43 AM   #2
johnnyrod
johnnyrod's Avatar
Default Re: Carb heaters needed?
They're there for when the engine is running on cold-ish days (or worse). Some people say they're useless, I've also been told that you'd know if they weren't working (some people on here had that problem). I'd keep them.
Old 21-08-12, 11:44 AM   #3
Nah get rid.
I've iced the carbs with them fitted and permanently on. More complexity.
You can get round carb ice by adding a small dosage of isopropanol to the fuel.
Take it you are not intending to race in freezing fog?
Old 21-08-12, 12:11 PM   #4
speedyandypandy
You never know.
Old 21-08-12, 12:27 PM   #5
m1tch_1987
Hmm a mixed bag of answers it seems lol the engine will only be run at a drag strip so won't be open or running when its snowy etc. Would it make a difference if I was running a different fuel eg meths rather than petrol? It will only be used for a 1/4 mile at a time
Old 21-08-12, 12:39 PM   #6
Don't worry about carb ice. It will be fine.
Old 21-08-12, 01:27 PM   #7
m1tch_1987
Ok the whole engine will be exposed when running so im sure I can warm the carbs up if needed manually
Old 21-08-12, 01:30 PM   #8
They'll have an eighth inch of ice on them by the end of the 1/4 but meth doesn't seem to cause carb ice lik epetrol does
Old 21-08-12, 05:44 PM   #9
embee
embee's Avatar
2 things I can see here.
1 - for what you're doing, no you don't need them as YC says, you really don't, honest.
2 - you're going to be running wide open throttle for a short period, the probability of getting icing under these conditions is very slim indeed.
The heaters are an attempt to reduce carb icing on the road, which usually happens at temperatures just a little above zero and small throttle openings held for prolonged periods when the pressure drop across the throttle causes the temperature change and moisture to freeze out and build up in the inlet tract. Running WOT minimses the press drop so tendency to ice is much less anyway. Aircraft can get icing in quite surprisingly high temps but they are up in the clouds etc. so very different atmosphere.
If you were running alcohol fuel it would probably reduce the tendency for ice to form inside the tract, just as IPA does when added to petrol, the alcohol attaches to the water which interferes with the crystallisation (as I understand it).
Even if you did get icing, the heaters won't do anything significantly useful anyway. You don't need them.
Old 21-08-12, 05:47 PM   #10
m1tch_1987
Thanks embee, so basically I just need to run WOT all the time then shame :P
Carb Heaters thedonal SV Talk, Tuning & Tweaking 17 08-01-09 03:29 PM
Carb heaters drag Stuff Wanted 5 29-09-08 01:28 PM
Are my carb heaters draining my battery? svrash SV Talk, Tuning & Tweaking 12 27-12-06 11:13 PM
Carb Heaters (again) anyone got the part #? echomadman SV Talk, Tuning & Tweaking 8 12-01-06 06:36 PM
carb heaters rastas SV Talk, Tuning & Tweaking 8 12-03-05 05:19 PM
