Old 22-08-12, 03:47 PM   #1
Nobbylad
Nobbylad's Avatar
Default Rear brake pressure switch
Anyone know if this plugs straight in?
http://www.ebay.co.uk/itm/Brake-pres...item4844f9d208
Ta
Old 22-08-12, 03:55 PM   #2
jambo
jambo's Avatar
Default Re: Rear brake pressure switch
The thread pitch (M10 x1.25) would need to be the same as the rear master cylinder. Asuming that's correct then it should be very simple.
To double check, what rear master cylinder do you have? - Standard pointy SV650?
Jambo
Old 22-08-12, 04:00 PM   #3
Nobbylad
Nobbylad's Avatar
Sorry, should have been more specific, it's the right thread M10x1.25, I was more interested in whether it would plug in as a straight swap with the wiring connector provided (to a '08 pointy).
oil pressure switch jim c Stuff Wanted 7 01-08-11 06:11 AM
Rear brake light switch yorkie_chris Stuff Wanted 1 04-06-11 08:45 PM
sv650 pointy rear brake switch curlylee Stuff Wanted 0 02-03-10 04:35 PM
Rear brake light switch dirtydog Stuff Wanted 4 29-12-06 08:50 PM
Rear Brake Switch machra SV Talk, Tuning & Tweaking 2 16-06-05 10:22 AM
