Old 11-09-12, 10:14 AM   #1
m`baubz
Default bike developed coolant-ary incontinence (curvy)
hi everyone, how's your day?
lately i've been finding puddles of coolant under the bike the next day after a ride. its leaking where the hoses connect to engine block and water pump. hoses themselves look allright, no cracks or anything, and some of the connections have never been touched, at least as far as i know.
last time, although the bike had been sitting for nearly 24 hours, i found the radiator hoses were stiff and undoing the rad cap released some air pressure.
now, i did have the coolant out and the radiator off several weeks ago, when i messed with CCTs, but the problem didn't appear right after that, only after a long ride two weeks ago.
any ideas on what could be causing this?
cooling system not bled properly? blown head gasket? radiator cap? something comes at night and scares the shizzle out of it?...
Old 11-09-12, 11:15 AM   #2
Serdna
Default Re: bike developed coolant-ary incontinence (curvy)
Radiator cap?
Old 12-09-12, 03:40 PM   #3
-Ralph-
+1 on radiator cap
Old 12-09-12, 03:57 PM   #4
Radiator cap.
Do the jubilees on the hoses also, mine went after 9 years (6months) with me. Its a 10 minute job and costs a quid
Old 12-09-12, 09:34 PM   #5
monkey
We need an explanation ladies.
Old 12-09-12, 11:11 PM   #6
Dabteacake
They radiator caps self bleed now and if it packs up it pressurizes the system. Because he said the pipes are still hard after 24 hrs assuming this is why people are saying its the cap
Old 12-09-12, 11:13 PM   #7
monkey
I don't get how air is sucked into the system (which it must be if there is pressure behind it when the bike is cold).
Old 12-09-12, 11:30 PM   #8
Dabteacake
its a release valve doesn't draw it in just doesn't relieve the internal pressure
Old 12-09-12, 11:35 PM   #9
monkey
Sorry, I thought he'd released pressure more than once.
Old 13-09-12, 06:39 AM   #10
-Ralph-
OK - One possible theory is - When you switch off your engine coolant flow stops, if the engine block is very hot it can boil. That expands and turns to steam and the extra pressure has to go somwhere. That somewhere should be the radiator cap, but if it cant get out there it finds the only other place to bubble out, which is your expansion bottle. As the steam comes up the pipe work to the expansion bottle, it pushes coolant up that pipework raising the coolant level in the bottle. The bottle has an overflow pipe and thats where the incontinence comes from.
Random Coolant overflow - Curvy. victor_meldrew SV Talk, Tuning & Tweaking 11 01-04-12 08:14 PM
Coolant Gary C SV Talk, Tuning & Tweaking 3 14-08-09 11:29 AM
Windows seems to have developed a sense of humour DarrenSV650S Idle Banter 14 31-10-08 12:42 PM
Curvy coolant AndyBrad SV Talk, Tuning & Tweaking 8 19-08-08 03:19 PM
Noisy bike, coolant low? TheStudent SV Talk, Tuning & Tweaking 5 09-02-08 09:31 PM
