Old 13-09-12, 09:22 PM   #1
bikermike
Default Fuel Tank filler cap - no key.
Hi,
I have just got a replacement fuel tank for my naked curvey but I have a problem
The fuel tank filler cap doesn't have a key!
I'm looking for any suggestions to get it open, preferably that doesn't involve drilling the lock! (although I will if there is no alternative!)
Thanks
Old 14-09-12, 01:12 AM   #2
Barty_b0y
Default Re: Fuel Tank filler cap
Locksmith
Some are cheaper than you think other are robbing Fecks
Old 14-09-12, 10:20 PM   #3
phil24_7
Default Re: Fuel Tank filler cap - no key.
Screwdriver? Pretty sure you should be able to prize out the internals allowing you to unlock it!
Old 14-09-12, 10:59 PM   #4
suzukigt380paul
just undo the 4 allen bolts that hold it to the tank and swap it for your old tank cap
Old 15-09-12, 03:31 PM   #5
bikermike
Tried that but it is still held in place!
Old 15-09-12, 05:50 PM   #6
suzukigt380paul
will just check my suzuki petrol cap,but am fairly certain if you undo all the allen bolts,half of which are dummy ones, and the other 4 screw into the tank that the cap will come out,but may be the lock catchs under the tank lip!
just looked and it does catch under the tank lip,so the only way you might get it undone is if you have a tank sender for a fuel gauge,and take this out and you might be able to push the front catch on the cap to undo it,as the catch seems to work like a yale lock
Old 15-09-12, 06:58 PM   #7
phil24_7
I butchered by CBR one with a f**k off big screwdriver! LOL
Rusty fuel filler cap? ScottishRawker SV Talk, Tuning & Tweaking 2 16-04-11 09:06 PM
Fuel Filler cap and other bits bigtony1702 SV Talk, Tuning & Tweaking 4 17-03-09 07:57 PM
Cleaning fuel filler drain Tomtoms Bikes - Talk & Issues 2 21-08-08 06:49 PM
Tank bag which allows access to fuel filler Chipstix Bikes - Talk & Issues 13 23-03-08 05:57 AM
Fuel filler cap..which way does it open on your bike Anonymous Bikes - Talk & Issues 19 12-11-05 06:05 PM
