Old 16-09-12, 05:07 PM   #1
scotty217
Default Front brake lever travel?
So on my Bikesafe course (see new thread in Bike talk) one of the instructors had a squeeze of my front brake lever when bike standing still. He didn't say anything but he's made me a bit paranoid. Now as far as I'm aware my brakes give me good braking effort, I've never failed to stop (good thing really , but you know what I mean) and when I've squeezed more they've braked more.
But if you squeeze hard enough at a stand still i can get the lever back to the bar. I've got newish pads and disks (about 500 miles new) on the front and also new fluid. I've bled them til i'm blue in the face, and I've got fluid only coming outta the nipples with no air bubbles.
Any one have any thoughts?...Questions?
Old 16-09-12, 05:14 PM   #2
k1ngy SV
Default Re: front brake is a bit erm...
thought about changing your lever setting ?
Old 16-09-12, 05:23 PM   #3
Elliott
Could also be air in the system. A re-bleed will sort that out.
Old 16-09-12, 07:13 PM   #4
sunshine
cable tie the brake lever to the handle bar over night, air will rise through the system, if that doesnt stiffen it up re-bleed.
Old 16-09-12, 08:50 PM   #5
speedyandypandy
For quick bleeding I use three bleeding points, the bleeding points on the calipers and the banjobolt on the mc.
Old 16-09-12, 08:54 PM   #6
Shawthing
Shawthing's Avatar
Master cylinder refurb or braided lines may be needed
SK9 Sport Black Delkevic can.
Old 16-09-12, 08:59 PM   #7
Dave-the-rave
Dave-the-rave's Avatar
Maybe you're being paranoid. See below for a clue...
SV650N K1
Dave-the-rave is offline   Reply With Quote
Old 16-09-12, 09:00 PM   #8
scotty217
Ok thanks all, will look into all of these. How do you bleed the banjo bolt on the master cylinder? And how does ty wrapping the lever release air?
Thanks again
Old 16-09-12, 09:08 PM   #9
svrich
Undo the banjo bolt very slightly as you squeeze the brakes on, then tighten as the lever touches the bar. holding the lever back to the bar will open the system and allow any air to rise up the lines and into the resevoir. I had to do all three points and wire the lever back several times, when I fitted braided lines, before the 'solid' feel came.
Old 17-09-12, 08:57 PM   #10
scotty217
Default Re: Front brake lever travel?
ok, an update. I tie wrapped my lever back last night and adjusted my lever setting. and all is much better. Yeah I was being a bit paranoid but after all the brake work i did i feel that my brakes are much better overall. They were never bad they are just better now.
Anyway thanks all, and I'll keep the tie wrap and banjo bolt tips for later.
Front brake issue, long lever travel. FG1 Bikes - Talk & Issues 3 18-05-12 02:15 PM
Excessive front brake lever travel. Amadeus Bikes - Talk & Issues 17 03-04-12 06:58 PM
Long brake lever travel. chester_dio SV Talk, Tuning & Tweaking 1 22-12-11 09:34 AM
Re: Front Brake lever travel Whyte25 SV Talk, Tuning & Tweaking 5 08-01-11 07:04 PM
brake lever travel ophic SV Talk, Tuning & Tweaking 73 08-05-09 03:52 PM
