help my starter solanoid has broke , its where the live and nutral main wires goes , has two fuses in it , is it just the suzuki one that will fit , its a sv650s 1999 curvie i have , if order one of ebay will take a good few days to come . i need bike asap so want to see what eles fits , as carnt use bike till i get one
thanks Last edited by craig dow; 19-09-12 at 07:23 PM. |
Take it off, take it to local bike breaker and say "one of those or similar my good man" shouldn't be more than a couple of quid.
thanks for that , but will any other bike ones fit it ? work on sv650s
Quick search using the part number for the relay 31800-21E20 brings up this site http://www.powersportsplus.com/parts...FUdvfAodZTUAdA (american though) and gives a list of bikes that use that same part. Needs to be checked for accuracy though.
Im with Thunderace in that if you take it in to a breakers they should be able to find a match. HTH xGx
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
Almost any solenoid should be able to be bodged in.
It is a device in 2 parts. There is the solenoid and the main fuse part. The solenoid, if desperate, isn't needed. You can just short the terminals together with a spanner to start the bike. The main fuse is required... but you can directly wire a main fuse to the loom using spade terminals.
ok thanks , went to breakers and got one , luck like , as dont have many sv parts , thanks for all your help
Main Solenoid Curvy SV | hardhat_harry | Stuff Wanted | 0 | 16-06-11 02:49 PM |
Alternative headlight for curvy 'N'? | mrhighlyrated | SV Talk, Tuning & Tweaking | 4 | 04-06-09 03:40 PM |
alternative headlight for a curvy | Nicky S | SV Talk, Tuning & Tweaking | 4 | 15-04-09 12:18 PM |
Alternative mirrors for a Curvy S? | svrich | SV Talk, Tuning & Tweaking | 9 | 26-03-09 10:22 PM |
Alternative mirrors for curvy svs?? | dmc2373 | SV Talk, Tuning & Tweaking | 3 | 15-02-05 08:30 AM |
