Old 25-09-12, 05:20 PM   #1
pistolpete
Exclamation SV650s Pointy bits wanted!
Hi all!
Due to some absolute scrote driving into my parked bike and then driving off without leaving a note, I am in need of a clutch lever, gear lever, front indicators and (if I'm lucky) full fairing. I have a 2007 SV650s K6 in Yuclaise silver metallic (the light blue/silver colour).
Help is mega appreciated on this one, I'm so angry about it I'm silent...
P
Old 25-09-12, 07:03 PM   #2
Jammy
Default Re: SV650s Pointy bits wanted!
Uh, would a curvy lever fit a pointy? if so i can send you mine
Old 25-09-12, 07:47 PM   #3
pistolpete
Hi Jammy,
Thanks for the response! From looking around the online shops, it doesn't look like it. No worries though, I have ordered one. I am in need of a replacement left-side fairing though. I've also taken a punt on a gear lever I hope will fit?!
Old 26-09-12, 06:08 PM   #4
phil24_7
Which fairing panels are damaged and how damaged are they?
You thought about taking it to a decent local garage? Preferably a garage that may like a cash job to help cash flow?
Regards
Phil
Old 26-09-12, 06:15 PM   #5
pistolpete
Hi Phil,
Only LHS fairing lower is damaged around the crash bung, as when it was knocked over, the force pushed the bung into the fairing and cracked it. I do have a local garage who can do plastic welding, but he's already told me it's not cheap. Thinking about ditching the lowers (selling the RHS) and replacing with just a belly pan. Was two weeks away from renewing my insurance and being able to afford a newer/nicer bike. Gutted.
Old 26-09-12, 06:25 PM   #6
phil24_7
I take it you mean the standard fairing fixings? If you decide to keep the lowers, get yourself of R&G's, they will stand up to a lot more and will actually protect your fairings. How badly is the fairing damaged? Post a picture because proper plastic welding is expensive, if it is just some small cracks, they are cheap and easy to sort. You can even go as far as to use bridge-a-gap (fiberglass filler) or even fiberglass matting over the back as these bits wont be seen (though you wont be able to go too thick due to this being a mounting point for the fairing).
Regards
Phil
Old 06-10-12, 06:48 PM   #7
curlylee
hi i have a mint lower fairing in that colour not sure which side it is,will have a look and let you know
curlylee is offline   Reply With Quote
Old 06-10-12, 08:36 PM   #8
Beetrootkiller
I've got all 4 standard indicators so let me know which you want if any
Old 06-10-12, 11:35 PM   #9
pistolpete
Awesome, thanks. Will post a pic of the damage tomorrow. I bought the cheap bungs, which bent the bar they fix to - I was told the R&G ones actually work... I will listen next time!
Old 07-10-12, 09:29 AM   #10
phil24_7
The fairing can also be repaired by using fibreglass on the rear of the panel and fillering over the front. It's not a perfect solution but a damn sight cheaper, it all depends how bad the damage is so get a photo up and we can advise you the best course of action.
Regards
A few bits from my old SV650S Pointy Sarg For Sale - SV's and SV related items 11 26-08-10 05:46 PM
Pointy Naked bits Wanted DarrenSV650S Stuff Wanted 10 07-06-10 06:44 PM
Wanted: Lots of pointy bits DaveW_42 Stuff Wanted 1 23-09-09 10:34 AM
Wanted: Bits for a K4 pointy Bumblecat Stuff Wanted 0 30-05-09 06:00 PM
WANTED: bits for a Pointy.... Monkey_SDMF Stuff Wanted 0 03-11-08 02:46 PM
