Old 26-09-12, 06:00 PM   #1
Merv121
Default indicator bulb blown.
i have looked in the search forum, but could not find it there,
but i was on way home from work tonight and went to indicate right, and on the dash the green flashy bit was flashing like it was on steroids, only for me to find out the right indicator(front) has stopped flashing all together, what are the possible causes/ fixes for this, and how easy are each of these :/?
Thanks in advance
Martyn
Old 26-09-12, 06:18 PM   #2
Bluepete
Bluepete's Avatar
Default Re: indicator issue
Take the bulb out, check it and replace if blown. If not, give the contacts on it and in the housing a clean, squirt of WD-40 and refit.
Should do it.
Old 26-09-12, 07:53 PM   #3
Merv121
by the contacts which bit do ya mean? sorry for bein so stupid , just slightly concerned as i cant get to any mechanics for at least 5 days
Old 26-09-12, 08:24 PM   #4
Bluepete
Bluepete's Avatar
It's the metal bits. Indicators can get wet and the metal will corrode. On the bulb, just wipe the metal off and inside the Indy housing, look at the copper coloured metal and clean off with a scrap of sandpaper.
Old bulb indicator to new LEDs? Springbokki Bikes - Talk & Issues 1 26-02-11 10:30 PM
is this likely to just need a replacement indicator bulb TechJinx SV Talk, Tuning & Tweaking 5 19-06-08 02:12 PM
indicator Bulb 'help'!! Blue_SV650S SV Talk, Tuning & Tweaking 23 12-07-07 08:48 AM
Can I paint the indicator bulb orange?! StreetHawk SV Talk, Tuning & Tweaking 16 02-04-07 04:22 PM
Help please, blown dash / indicator / rear light fuse Filipe M. SV Talk, Tuning & Tweaking 6 02-04-07 12:15 PM
