Old 01-10-12, 04:03 PM   #1
rivsm
Default Bike switching off when first gear is engaged after clutch adjustment
Hi
I have just attempted to adjust my clutch on my 2000 sv 650s after an oil top up. Now after the adjustment when i start the bike in neutral and then engage first gear with the clutch lever held in the bike switches off.
What have i done incorrectly?
Any help appreciated.
Thanks in advance
Old 01-10-12, 04:06 PM   #2
Galviniser
Simple checks? Is the stand switch working correctly?
Sent from my iPad using Tapatalk
Old 01-10-12, 04:08 PM   #3
Biker Biggles
Biker Biggles's Avatar
Default Re: Bike switching off when first gear is engaged after clutch adjustment
Is it stopping with a jolt because the clutch will not disengage,or is it just cutting out when you engage first because the electrical cut out switch that detects the side stand being down is now oversensitive?My guess is it will be one or the other,as you have been working around that area.
Old 01-10-12, 04:10 PM   #4
Galviniser
True, could be stalling...did you put the same oil in as last time? Is it the right oil? I'm not trina be funny or out, just trina help but these things matter lol
Old 01-10-12, 04:20 PM   #5
rivsm
Stand switch good. It stops with a jolt as it feels the clutch will not disengage.
Old 01-10-12, 04:55 PM   #6
rivsm
Used recommended oil. Now after adjusting I have no clutch at the lever, extremely loose. Any suggestions
Old 01-10-12, 04:56 PM   #7
TamSV
TamSV's Avatar
You need to have another go at the adjustment. Adjust at the engine end first and then at the lever. Very good thread on clutch adjustment here.
Old 01-10-12, 05:07 PM   #8
Galviniser
Haynes manual
Old 01-10-12, 05:56 PM   #9
if you striped the worm gear down to clean it then you might have put the half moon shaped bracket underneath instead of on top.
Old 01-10-12, 05:57 PM   #10
mattSV
mattSV's Avatar
Also double check the oil level - overfilling has been known to cause clutch issues
2000 - 2004 SV650S
2004 - 2009 SV1000S
Clutch adjustment? SIII SV Talk, Tuning & Tweaking 9 27-02-12 11:16 AM
Clutch adjustment -Ralph- SV Talk, Tuning & Tweaking 16 29-05-09 11:48 AM
Clutch adjustment Dave20046 SV Talk, Tuning & Tweaking 13 22-09-08 03:41 PM
clutch adjustment mlrz4 SV Talk, Tuning & Tweaking 0 09-07-07 11:18 PM
Switching from car to bike linco Idle Banter 4 21-06-06 08:02 AM
