Old 07-10-12, 02:36 PM   #1
HighamSV650S
Default SV650S swingarm nut/ abba stand
Hi, looking for some help. I recently bought a 2003 SV650S. I've just got an Abba stand for it together with the correct fitting kit. However, the swingarm locking nut is flush with the end of the bolt. The fitting kit is clearly the correct size but obviously has nothing to hold onto as the end of the bolt is not proud of the nut. Has anybody come across this before? I'm guessing that maybe the nut needs torquing up, but I'm going to have to get the special socket before I can try that. Does that sound likely or is there anything else I should be aware of? Thanks, Rob
Old 07-10-12, 04:52 PM   #2
Default Re: SV650S swingarm nut/ abba stand
Are you doing it right? The stand adaptor ordinarily is to be inserted into the hollow swingarm, not around it. Adaptor back to front possibly?
Old 07-10-12, 10:01 PM   #3
HighamSV650S
Thanks Sid, you're quite right. Schoolboy error on my part, what a numpty! All sorted now, thanks for your help.
Sv650S k4 abba stand adaptors Suchy Stuff Wanted 1 06-05-12 12:09 PM
SV650S Curvy Abba stand kit carpet monster Stuff Wanted 0 10-07-11 06:03 PM
Abba stand fittings for SV650s (Curvy) benji106 Stuff Wanted 4 19-06-11 10:07 AM
Swingarm pivot sliders on bike-can I still use an abba stand? monkey Bikes - Talk & Issues 7 26-03-09 04:34 PM
SV650S ABBA stand bobbins 03 - KnightRider Stuff Wanted 0 16-09-07 07:31 PM
