Old 14-10-12, 04:07 PM   #1
John D
Default Clutch push rod replacement?
Snapped the chain and clutch push rod on my K3 SV650s recently. Not sure which bit went first?! One failing broke the other I guess - suspect it was the snapped chain lashing around.
When I moved the clutch actuator out of the way to get at the front sprocket part of the push rod fell out. I've fitted the new chain and sprockets - my first time following the Haynes guide, wasn't too bad. Now I'm wondering how easy it is to fix the clutch. Any tips and advice for fitting a new push rod? I'm a bit scared of having to take loads of pieces off to get to this part tbh!
Bike is on nearly 30k btw. Hadn't noticed anything un-toward with the clutch prior to this happening.
Old 14-10-12, 04:21 PM   #2
Tomor
Tomor's Avatar
Default Re: Clutch push rod replacement
when mine happened, removed the oil seal got a new rod and seal and slipped them in. The rod is split into two bits and only the LHS of mine snapped so it was ok. I am sure Rictus will be along in a bit to clear things up and help, He did with me
Where are you BTW?
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 14-10-12, 04:35 PM   #3
John D
I didn't realise it was in two bits. How long is the left hand bit of the rod? The piece that fell out looked like it had snapped off to me from the condition of one end. I'm no expert though!
I'm in Reading.
Old 14-10-12, 04:41 PM   #4
Tomor
Tomor's Avatar
I am over near camberley if you need a hand?
Old 14-10-12, 05:06 PM   #5
Default Re: Clutch push rod replacement?
If you broke a chain then a damaged rod is likely, the external part of the rod simply pulls out of the seal in the cases, remove it and examine it carefully - it's bent or otherwise damaged the clutch probably won't work properly, if it isn't obviously damaged refit it and adjust the clutch, if it works OK it is OK.
Clutch adjustment:
Originally Posted by Me, lots
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod, back it out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
Old 20-10-12, 11:34 AM   #6
John D
Yep definately snapped the outer push rod. Ordered a new one and seal.
Thanks for the help and advice chaps.
Curvy clutch push rod oil seal - Free to a good home 7755matt For Sale - SV's and SV related items 4 21-05-12 03:54 PM
K5 650S clutch push rod seal. jhogue88 Bikes - Talk & Issues 3 23-05-11 11:06 AM
Clutch Push Rod and Seal Binky Stuff Wanted 2 25-06-10 08:45 PM
Rod, Clutch Push Lh peahead Stuff Wanted 4 04-02-08 09:28 AM
Urgent Help Needed - Clutch Push Rod 01 sv650s SV Talk, Tuning & Tweaking 5 30-01-08 01:37 AM
