Old 15-10-12, 05:45 PM   #1
Amadeus
Default Lights on push bikes
Whats the position of lights on a push bike?
I was in traffic (in car) coming up to junction and a push bike was trying to come up the inside of the cars behind me. It had a front light that was I think led but very bright and flashing - probably about 3 times a second. Saw later that it was the same on the back (in terms of flashing - wasn't as bright).
It was really annoying and I found it distracting as well.
Are these lights legal?
Old 15-10-12, 06:10 PM   #2
Default Re: Lights on push bikes
From what I remember, and things might have changed, both front & rear lights should be fixed ie not flashing.
But there's nothing to say you can't supplement the fixed lights with the flashing LED's
However, as a cyclist it maybe a bit annoying to you, but you've noticed him. Better than a rider with no lights, which is infrequently the case these days and better than when I was young and the pathetic lights we used to have.
Old 15-10-12, 06:17 PM   #3
Spank86
I believe it did change a few years ago so that just having a flashing light was acceptable.
On a personal level I think it's dangerous, I've had a bike with a flashing light near me that I couldn't see for a bit because the lamp was obscured during the first few flashes and I wound up having to brake harder than I'd have liked when I finally did spot it.
Old 15-10-12, 06:18 PM   #4
fizzwheel
fizzwheel's Avatar
I think the law has changed and you can have a flashing light now but I'm not 100% sure.
It might be annoying, but flashing light is better than none and you did see him...
On the rear I run two lights, one set to flash and one set to constant on the front. I have one set to constant, but only because I broke the mounting bracket on the flashing one...
Edit - Flashing light is legal according to this...
http://www.ctc.org.uk/desktopdefault.aspx?tabid=4071
Old 15-10-12, 06:26 PM   #5
missyburd
YC and me were discussing bike lights just last night after being blinded while out in the van by a cyclist with a light that would rival my SV's. On a pitch black road I actually thought it was a motorbike to close to the side of the road. Better to be seen of course but a bit over the top. Apparently push bikes are not legally required to adjust their lights to suit other road users...and it shows!
Old 15-10-12, 06:34 PM   #6
Runako
Its less dangerous than no lights, as has been pointed out. But glad it meant the question was asked cause it means hopefully we're more considerate/aware of all road users. Cyclists get a bad rap sometimes and some are annoying. But, as with motorcyclists, its the few who tend to give the majority a bad name.
Originally Posted by missyburd View Post
...and it shows!
Didn't adjust my headlights in France. Some bikes don't have a reflector on the tail light (MOT fail). I'm betting we all commit little indiscretions. But there's a difference between being outright dangerous and inconvenient. If its a temporary annoyance then I would put it in the first category (although whether this is truly dangerous is debatable). But then we all moan about modern cars using dazzling HID's, some of which are just legal.
Old 15-10-12, 09:21 PM   #7
Amadeus
TBH, he just made me want to knock him off - I thought it was very inconsiderate. But then I also think very loud exhausts are inconsiderate.
That aside, I thought it might be illegal for the same reason two (or more) notes in a horn is - confusion with emergency services.
Old 15-10-12, 09:29 PM   #8
fizzwheel
fizzwheel's Avatar
I'm curious as to why you felt like that.
Old 15-10-12, 09:39 PM   #9
Amadeus
Well, it was *very* bright and because it was flashing it was very visible in the wing mirror and the rear mirror and I found it very distracting. Whilst I'm generally tolerant of most things, I'm very intolerant of people being inconsiderate and I felt this to be inconsiderate.
Interestingly enough, when I overtook him (after he'd undertook me and got on to the main road - I had no problem with the filtering), there didn't actually seem to be very much light directed at the road ahead of him.
I'm all for cyclists making themselves visible (as per bikers) and as some have previously said, it's a shame when a few give the rest of any collective a bad name. This was one of them.
Old 15-10-12, 09:45 PM   #10
fizzwheel
fizzwheel's Avatar
Sounds like it was badly aimed / adjusted. No point in having it if it isnt lighting up the road.
I have mine set so it points down and to the left so that I keep it out of car drivers eyes.
People with push bikes, help please? AndyBrad Idle Banter 24 04-02-11 10:48 AM
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Question about push-bikes... vixis Idle Banter 26 22-12-08 02:59 PM
What bikes have GOOD lights then? richwill68 SV Talk, Tuning & Tweaking 33 04-06-08 02:57 PM
Why don't bikes have fog lights....... Tigerrrr....... Bikes - Talk & Issues 35 21-02-05 11:47 PM
