16-10-12, 02:41 PM | #1 |
Curvy rear brake light switch?
Bought a new brake light switch today, only to get back and remember I have aftermarket rear sets so a non standard switch, its a screw in type at what looks like the top of the master cylinder. Any idea which it might be?
16-10-12, 03:10 PM | #2 |
Re: Brake light switch
That sounds like a pressure switch in the brake line. Replacing it will require some elements of re-bleeding your rear brake system.
Check with a multi-meter that it's definitely shot Jambo
Modern motorcycles are bloody brilliant, enjoy it while we can |
16-10-12, 03:13 PM | #3 |
So annoying nothing on the bloody bike is simple and standard, certainly does not look like the standard pull switch with the spring it goes in the side.
Where do I test with my multimeter? |
16-10-12, 03:17 PM | #4 |
Follow the wire up from the switch there should be a plug, undo this and get a multi-meter across the terminals on the brake switch side.
Apply the rear brake good and hard See if the continuity between the 2 terminals is "made" as pressure is applied (resistance should drop to 0, or get a beep if you have a continuity tester) Jambo
16-10-12, 03:31 PM | #5 |
Re: Brake light switch?
16-10-12, 05:48 PM | #6 |
Yep no continuity on the switch at all. Any idea where to get one or which it might be?
Sent from my Samsung Galaxy S2 using Tapatalk 2 |
16-10-12, 06:40 PM | #7 |
What pitch thread would the banjo pressure switch be? I found 1mm or 1.25mm.
17-10-12, 12:28 PM | #8 |
Sorted got new switch from local parts place.
Curvy Undertray and LED indicators above rear light & flashing rear brake light | ThePone | SV Talk, Tuning & Tweaking | 17 | 07-06-12 10:25 PM |
Rear brake light switch | yorkie_chris | Stuff Wanted | 1 | 04-06-11 08:45 PM |
curvy rear brake light | mike_red2uk | For Sale - SV's and SV related items | 0 | 02-05-11 02:09 PM |
Curvy Rear Brake Light | Binky | Stuff Wanted | 2 | 30-07-10 07:20 PM |
Rear brake light switch | dirtydog | Stuff Wanted | 4 | 29-12-06 08:50 PM |
