Old 16-10-12, 08:19 PM   #1
bluebeast
Default wanted: curvy rear brake lever and rear right indicator
Hi all,
does any one have a rear brake lever/pedal for a 1st gen curvy?
Also, a right hand side rear indicator - just the big standard oe ones not a small indie.
Any one got either?
How much?
cheers
Old 16-10-12, 08:29 PM   #2
trudd
Default Re: wanted: curvy rear brake lever and rear right indicator
I've got a pair of rear indicators that have had the connectors cut off. £5 plus post sound reasonable?
Old 16-10-12, 08:39 PM   #3
bluebeast
cheers Trudd, sounds good.
Is it easy to get the connectors back on them?
Old 16-10-12, 08:45 PM   #4
trudd
The best way to do it would be to cut the connector from your broken one and solder it on. (assuming you have a connector)
You could just use a "chocolate" block or scotchlok but my preference would be to solder a proper connector on
Old 16-10-12, 09:06 PM   #5
bluebeast
ok mate. chocolate connectors look easy enough.
please pm your details and we can sort it out.
Btw, are the indicators in good whole condition? no cracks etc?
cheers
Old 16-10-12, 09:17 PM   #6
trudd
Apart from the missing connectors they are like new.
I'll go to the post office tomorrow and get a quote for the postage and let you know.
Old 17-10-12, 05:26 PM   #7
trudd
pm sent
wanted: rear brake lever and rear right hand indicator for curvy bluebeast Stuff Wanted 0 16-10-12 12:46 PM
Curvy rear brake lever wanted Flybuster Stuff Wanted 12 29-09-11 08:05 PM
curvy indicator and rear brake lever wanted Flybuster Stuff Wanted 0 14-09-11 07:47 PM
curvy rear brake lever & indicator metal plates Paws Stuff Wanted 3 26-01-08 11:10 PM
Rear brake lever and front right indicator needed for K4 fraser01 Stuff Wanted 4 30-12-05 07:04 PM
