Old 27-10-12, 01:59 PM   #1
Tim in Belgium
Default Late 90's/early 2000s Alfa GTVs - what are they like as a road car?
As per the thread title - what are they like, charismatic/fun/wouldn't touch them with a barge pole?
Also how quiet/comfy are they inside?
Old 27-10-12, 03:08 PM   #2
Mr Speirs
Mr Speirs's Avatar
Default Re: Late 90's/early 2000s Alfa GTVs - what are they like as a road car?
Can't comment on the actual car but as an Alfa owner I can give an insight especially into the 2.0 petrol engine.
If you decide to go for the 2.0ltr then there are a couple of things you need to check before buying. Make sure the cambelt has been replaced, they need doing every 3 years or 36k miles. They are also designed to use oil. Roughly 600ml per 1000km. Not a lot of owners know this so running them with no oil tends to be the most common way of blowing up the engines. And where the reliability questions crop up.
The 3.0 v6 seems to be the one to go for and gets some proper good reviews. Expect 23MPG from it as a posed to 30ish on the 2.0.
Oh and check suspension bushes on the rear of these cars. They go commonly and when they do the whole rear arms need to be replaces. The fix is to fit power flex bushes houses within new rear arms.
Hope this helps a wee bit.
Old 27-10-12, 03:58 PM   #3
Tim in Belgium
Cheers for that, off for a look at one tomorrow.
Old 27-10-12, 04:35 PM   #4
Whitty
If anything like 156's check floors for rot, the steel they use is poor. Plus make sure everything electrical works!
Old 27-10-12, 09:29 PM   #5
Tim in Belgium
Are they not galvanised? Or is it crash damage issue?
Old 27-10-12, 09:37 PM   #6
Whitty
My foreman had a mint looking 51 plate 156 JTD model that failed its mot. The floors in the rear footwells were absolutely rotten. They looked like originals. Also on a hamfisted note, giving my neighbours 147 a push to bump start it (again) I dented the tailgate without hardly touching it. It felt as thin as a mackerel tin.
Old 27-10-12, 11:32 PM   #7
L3nny
L3nny's Avatar
I had a V6 156 and the engine was superb, liked a drink though.
Old 28-10-12, 09:21 PM   #8
Tim in Belgium
'Twas rusty towards the rear of the drivers side floorpan, and a few other minor issues.
Old 28-10-12, 09:27 PM   #9
chris8886
chris8886's Avatar
i may be wrong but i think i remember always hearing about a slight problem with alfa's is that quite often they have their airboxes or something in a stupid place, which means when you drive through a puddle the engine dies! i may well be wrong, but worth checking out!
AR08 to AR13-QUALITY!
Old 28-10-12, 10:18 PM   #10
jamesymurray
I had the 2.0 twinspark GTV. Loved it, and really regret selling it, but as you'd expect with Alfa's, it's not without its 'quirks'.
With mine, the drivers window wouldn't sit in the seals when the door was closed until you opened/closed the window.
The boot and back seats are laughably small.
The TS engine really seemed to come to life when given a bit of a tickle and was cracking good fun on the a roads.
There were a few more that I can't quite recall, but it was what was charming about it.
I'd buy another in a heartbeat if I could.
AFAIK they were galvanised so rust wasn't an issue
Track day late June/early July? johnnyrod Track Days 13 12-06-12 07:58 AM
Early morning rise/late night DJ123 Idle Banter 7 07-05-12 03:24 PM
Late 90's early 00's R&B song help _Stretchie_ Idle Banter 12 04-11-11 04:36 AM
Starter Relay\Solenoid early and late the same? Robert711 SV Talk, Tuning & Tweaking 1 26-07-10 08:52 PM
Help Needed Late 80's/Early 90's Hardcore Music? krhall Idle Banter 7 20-02-09 11:03 PM
