Old 28-10-12, 02:14 AM   #1
fatlad
Default Quick question
Hi guys , im going to be joining the army in 2month and im wondering for the best fitness should i do alot more running than cycling or more cycling than running? My current fitness training plan is tiptop ,
250 press ups, 250 sit ups , 400 star jumps , 50 dumbell curls at 15kg , and 70 pull ups and 3hour mountain bike ride
Old 28-10-12, 06:18 AM   #2
Mikey10
Default Re: Quick question
I'm no fitness guru but as you do 3 hours mountain biking do a bit more running and see how things go.
Old 28-10-12, 06:51 AM   #3
jandn1
Sound like your very fit to start with, would do more running and also get a rucksack with some weight in and wear that................ the speed march is a killer at the end of basic training. Well it was 24yrs ago!!!!!!!
p.s dont forget you will be carrying a rifle as well so may be practice running while carrying something.... it all zaps energy
Old 28-10-12, 12:21 PM   #4
fatlad
Cheers will start jogging on monday
Old 28-10-12, 12:53 PM   #5
Kenzie
Kenzie's Avatar
I did basic at Lichfield for Royal Signals but had to discharge for medical reasons. Cardio is the number one king for training, then upper body strength. Not sure if we had a sadistic PT (aren't they all???) but he made us relay run every single line in the hall (you know the coloured lines that mark out different games areas) one at a time until they were all done. They do lots of circuit training, sit ups, push ups, step ups, and squat jumps so you should be ok there. Once in, they do a regular fitness test which involves a 1.5 mile run, which they expect you to do faster than selection, also carry two full 20 litre jerry cans twenty meters and back, plus press-ups at some point. Also if you were an Army Cadet, try not to mention it too much as they send you off to one side when teaching some basics to raw recruits. My weapons training in cadets helped big time as most people have never held a gun before. Number one rule, if they ask you to do something, do it sharpish. Don't bimble or you will regret it. But once out of basic then the crappy stuff like that stops. What area of the Army are you going in to?
Old 29-10-12, 10:06 PM   #6
fatlad
Hopefully into the royal artillery mate
Old 29-10-12, 10:26 PM   #7
Calling Richie and Thunderace
Seriously get out running cross country, work on cardio and general weight work
Old 30-10-12, 10:40 AM   #8
In that case I can recommend starting playing with boats. When you've filled a 600 liter tank up 4 jerrycans at a time at low tide you'll p*ss that one!
Old 30-10-12, 06:28 PM   #9
Kenzie
Kenzie's Avatar
My brother is in 12 Battery RA at Thorney Island.
Quick question about HMV Specialone Idle Banter 6 12-02-11 07:51 PM
Quick Reg/Rec Question Binky Bikes - Talk & Issues 7 25-01-11 08:58 PM
Quick E Bay Question Quiff Wichard Idle Banter 11 31-07-08 11:54 PM
quick question Ward8124 Bikes - Talk & Issues 2 31-01-07 08:55 PM
Quick Question, Quick Answer JakeRS SV Talk, Tuning & Tweaking 6 07-05-05 11:00 PM
