For Sale - SV's and SV related items For SV's and SV spare parts only. 650 or 1000 No other items Unsanctioned trade ads will be deleted as will spam and chat. |
Hi All,
Have a few parts that I removed from my K3 SV1000. I bought the bike as my intended winter commuter and the parts that were on it are a bit "overkill" for me. I am happy with just a standard machine so the following is all available to you good folks before I eBay the lot - the eBay prices will go up as I have to account for their ridiculous fees: 1. Ohlins Rear Shock Great condition, recently serviced with new spring & seals (will include these as proof). Suited for a 12-13stone rider and it's fully set-up at the moment. May be interchangeable with some GSXR's, doubtful about the 650 but does warrant some investigation as it transforms the rear end of the bike (The OEM shock I just refitted is awful in comparison) £320 posted. 2. Ohlins Steering Damper Great condition again, no oil leaks and only 1 slight mark on the body (I only mention this out of honesty....99% of people wouldn't as it's just aesthetic). Fully adjustable and a doddle to fit. Installs in the same location as the OEM damper. £130 posted 3. Ohlins Front Springs Only 4 months old and less than 3k miles. Set-up for 12 stone rider, the springs are OHL-08695-90 type. £80 posted. 4. Ventura rack & top box In good condition, supplied with ALL parts to fit to SV1000. The rack has a top-box (unknown manufacturer) plate fitted and is supplied with a mint, approx 45L top box, finished in matching grey (to the Suzuki grey). £90 posted. 5. Topyokes.com CNC Top Yoke & Risers with Renthal barsh In great condition. Supplied with Top Yoke, risers, Renthal bars & replacement, longer throttle cables. Am unsure if this set-up needs longer brake lines made up, if it does I can swap mine for yours if you have braided lines also. Will also give you step by step instructions on how to fit these - it does take some time and patience but you are rewarded with a VERY comfortable riding position that, when used with a DB Screen, arguably gives you better wind protection. Go figure! £150 posted. Photos to follow, upon request. Thanks Last edited by instigator; 05-11-12 at 09:56 PM. |
Hi: can you post pics of rack and top box? - would these fit a K8 650? shug
Hi
![]() ![]() Fitment to a 650? No idea - could be worth an email to Ventura ![]() Infact, take a look at the part numbers, the part numbers for the SV1000S K3-K7 are precisely the same as the SV650S K3-L2. So on that basis, I'd say they are compatible but the responsibility isn't mine. I just know I took it off my thou' ![]() http://www.ventura-bike.co.uk/fitmen...0_s_k3_k7.aspx http://www.ventura-bike.co.uk/fitmen...0_s_k3_l2.aspx Thanks Last edited by instigator; 05-11-12 at 09:55 PM. |
I know you have already mentioned this, but was are the chances that the rear shock absorber will fit onto a sv650s k5?
Thanks |
I found this:
http://www.sv-portal.com/forums/showthread.php?t=31800: It suggests its compatible with a slight cutting of the battery box. Personally, I'd start another thread in the main section of the forum and ask - plenty folk on here will know the answer. |
pm sent re the rack and top box.
Ventura system wanted, UK | magsk1 | Stuff Wanted | 0 | 11-07-12 01:58 PM |
Ventura L Brackets for sv650s k5 | D Two Nine | Stuff Wanted | 0 | 21-08-10 10:21 AM |
Ventura Luggage - full system. | shonadoll | For Sale - SV's and SV related items | 0 | 18-01-09 02:25 PM |
Is Ventura luggage any good? | shonadoll | SV Talk, Tuning & Tweaking | 14 | 02-01-09 06:57 PM |
Pointy Ventura L brackets | Weeble | Stuff Wanted | 0 | 06-05-08 09:16 PM |
