Old 05-11-12, 11:19 AM   #1
Elliott
Default No low beam after HID installation.
Right I installed some HIDs recently and after a ride out yesterday the low beam will not work.
I have tried/tested the following:
Regular H4 (only worked on high)
The connector block for the headlight loom is not burnt out
The fuse has been replaced
And I'm still in the same position so do I buy a multimeter and do the check or replace the loom with a spare I have?
Are there any know issues to do with this?
Thanks in advance guys.
Old 05-11-12, 08:43 PM   #2
Default Re: No low beam after HID installation.
how do you mean the low beam wont work. its HID they don't have hi and lo bulbs. if its an H4 bi-xenon HID then its always on and there is a shield that moves or the bulb moves to create hi and lo.
Old 05-11-12, 09:52 PM   #3
unclepoo
start by going back to square 1 and un-plug the HID loom and re fit the H4 bulbs...now see whats happening.
the HID kit you need is a hi/lo kit...the bulb is moved when you switch from low to high beam.
Old 05-11-12, 09:56 PM   #4
Elliott
As above I have tried with a regular h4 bulb
And yes it moves when set to high. It has something to do with power delivery when switched on dipped beam only.
Old 05-11-12, 10:04 PM   #5
so its striking an arc on hi beam but not on low?
Old 05-11-12, 11:05 PM   #6
Elliott
Yea
Old 05-11-12, 11:12 PM   #7
does the kit have a relay?
does it have stupid switches to make it suitable for OBD?
Old 05-11-12, 11:50 PM   #8
Elliott
no relay.
The kit cannot be the issue tho as i have tried it with regular h4 bulbs and its not doing the same on there. to me it must be a broken connector or burnt wire?
Old 06-11-12, 01:19 AM   #9
NTECUK
NTECUK's Avatar
Check the white dip beam wire were it goes round the head stock.
when you get the H4 working , then re install the HID kit
Old 06-11-12, 01:18 PM   #10
Blueperson
If no relays then may have burnt out the hi/lo switch on the handle bars?
Delayed High Beam mikebrooman SV Talk, Tuning & Tweaking 4 04-02-10 01:02 PM
H.I.D H4 for sv hi low beam ging6996 For Sale - SV's and SV related items 4 28-07-09 04:49 PM
low beam not working. Slash SV Talk, Tuning & Tweaking 3 26-09-08 02:28 PM
High-beam light simesb SV Talk, Tuning & Tweaking 2 27-03-08 07:22 PM
