15-11-12, 07:08 PM | #1 |
2005 SV650 Headlight High Beam Dilemma
I checked the threads here and found several on faulty headlights, but none with my unique problem with a 2005 SV650 naked:
Low beam work fine, but high beam not working. Changed bulb, but to no avail. The high beam indicator works when the switch is used, as well as the passing switch, but no high beam light. I checked the voltage at the headlight connector and I get voltage for the low, but not the high. Fuses are OK. I am baffled because the switches are activating the indicator light. What else is there to check? Any help here would be greatly appreciated. |
15-11-12, 10:05 PM | #2 |
Re: 2005 SV650 Headlight High Beam Dilemma
The fault is in the yellow wire from the fuse to the light, but forward of the branch into the clocks as the warning light works. Look around the headstock area for damaged or trapped wiring.
16-11-12, 08:24 PM | #3 |
Sid Squid: You were spot on! I followed the yellow wire and found that there was a weak spot in the insulation indicating a break in the wire. It was at the point where the clip was holding the harness to the frame between the fork and the fuel cell. After joining the wires, soldering it, sealing it with shrink tube, and securing the harness wrapping with a fair amount of electrical tape, I am good to go. Your quick and accurate response is greatly appreciated. Cheers!
17-11-12, 08:54 AM | #4 |
Headlight problem on low beam | jono878 | SV Talk, Tuning & Tweaking | 12 | 21-10-10 06:57 PM |
Single headlight beam mod for RHS riding. | ejohnh | EuroTour | 4 | 31-05-10 04:55 PM |
Delayed High Beam | mikebrooman | SV Talk, Tuning & Tweaking | 4 | 04-02-10 01:02 PM |
No High Beam - but there is voltage (and yes the bulbs are ok...) | chris7231 | SV Talk, Tuning & Tweaking | 8 | 25-03-09 12:28 PM |
High-beam light | simesb | SV Talk, Tuning & Tweaking | 2 | 27-03-08 07:22 PM |
