Old 16-11-12, 01:38 PM   #1
Default connecting lots of stuff to the battery
is there an easy way ?
long battery screw> ?
I have too much stuff really now wired to my terminals..
what is the term for the thing you can buy that runs off the terminal using one connection then you connect the other stuff to said "thing" ?
ta
Old 16-11-12, 01:40 PM   #2
Tomor
Tomor's Avatar
Search powerlet termin 8. May be what you are after
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 16-11-12, 01:41 PM   #3
Default Re: connecting lots of stuff to the battery
Depending on space I would put a fuse and relay in... one wire to terminal, one wire from ignition etc.
Then from relay either a junction block or if tight for space make a little loom coming off it with spade or bullet connectors every few inches then it can lay down flat.
Old 16-11-12, 01:44 PM   #4
Converted
Get in touch with murraybatty@hotmail.com
He makes a plug-and-play loom that wires into the rear brake light switch that allows up to 6 devices to attach to it. It is fused and a doddle to fit. That way nothing is left on accidentally to flatten the battery.
I have heated grips and gloves on mine and will be fitting a phone charger and satnav for touring next year.
Old 16-11-12, 01:50 PM   #5
This.
Old 16-11-12, 03:15 PM   #6
Dicky Ticker
Hair straighteners,hair dryer,electric tooth brush,phone,GPS,Electric nasal hair trimer and electric razor---------------what else you got fitted?
Oops sorry electric pump for air bed plus a 12v socket.
Old 16-11-12, 03:30 PM   #7
muzikill
muzikill's Avatar
Prices? - gimme cos it'll make my mods easier to do during the winter!
CLEAR OUT! Lots of stuff... CURVY! MRedhead For Sale - SV's and SV related items 39 27-08-12 09:32 PM
connecting extras directly to the battery. musne SV Talk, Tuning & Tweaking 8 17-01-12 12:14 PM
Lots of pointy stuff from a low mileage 57 plate 650 Chris Bird For Sale - SV's and SV related items 20 15-08-11 07:51 PM
lots of stuff so look davepreston Stuff Wanted 6 20-03-09 01:24 PM
Lots of stuff for sale silent For Sale - SV's and SV related items 3 07-03-07 01:42 PM
