Old 16-11-12, 06:49 PM   #1
rs2fifty
Default Stainless exhaust clamp for Pointy front downpipe?
Hi everyone
I have a recently acquired a fully faired pointy 650S K6 and have just noticed the exhaust clamp that clamps the front downpipe to the centre section is really rusty, i havent managed to remove the fairing yet to see if there are anymore clamps in the same condition, but my 2 questions are:
Is the exhaust stainless?
And can i get replacement stainless clamps?
Old 16-11-12, 07:47 PM   #2
Default Re: Stainless exhaust clamps
Yes, the exhaust is stainless and will polish up nicely.
I replaced some of my clamps with mikalor marine grade stainless clamps.
Old 16-11-12, 10:43 PM   #3
rs2fifty
Thanks maviczap, where did you get your clamps from?
Old 16-11-12, 11:04 PM   #4
rs2fifty
I have just found them on web, could you tell me what size or sizes i need to order to replace those used on the exhaust please. Im assuming there is likely to be 2
Old 16-11-12, 11:08 PM   #5
embee
embee's Avatar
+1 for "Mikalor", the items I've used from them have been very decent quality. "Norma" is another very good make of clip.
Search fleabay, loads of suppliers. (edit - beat me to it)
Old 16-11-12, 11:59 PM   #6
some are not the same as others so beware SS ones. the ones you want are the ones with SS bolts.
Old 17-11-12, 07:33 AM   #7
That's why I said marine grade clamps, the bolts are SS
I'll get the clamp sizes later
Old 19-11-12, 06:53 PM   #8
rs2fifty
Hi Guys
Any luck with what size clamps i need to replace my rusty steel ones on my exhaust please
Old 19-11-12, 09:13 PM   #9
Default Re: Stainless exhaust clamp for Pointy front downpipe?
Which ones do you need?
The one where the header joins the collector box under the engine & the one which clamps the header pipe to the rear exhaust stub pipe?
Old 19-11-12, 09:52 PM   #10
rs2fifty
Yep, thats the two im after maviczap.
Is there some gasket seals that slip in there as well?
Exhaust wrap on front downpipe? Jordy SV Talk, Tuning & Tweaking 10 18-07-10 07:20 PM
Exhaust Clamp For Pointy SV Seggons Stuff Wanted 4 16-05-10 07:27 PM
Exhaust,front downpipe clamp. ejohnh SV Talk, Tuning & Tweaking 4 18-08-08 11:54 PM
Stainless exhaust clamp ? oldjack SV Talk, Tuning & Tweaking 2 27-02-07 10:55 PM
Rear downpipe from standard exhaust system (Pointy) Bez Stuff Wanted 15 27-02-06 04:57 PM
