Old 20-11-12, 04:46 PM   #1
alfa.rbt
Default Condensation inside a headlight.
Bike - zx6r B1H. Stupid problem really but it's still a problem. It's been like that for a while (a little bit on dipped light and a lot on high beam as it's not used a lot) so I decided to get it sorted. I dried it all out usig a hair dryer, also I put some red rubber grease on cover seal so no air gets in there. Took it for a 30 min spin to the cafe, stayed there for 2h and when got back, it was same again - dipped was misted up and high beam has drops of water runing down a inside of a headlight. I'm puzzled so any ideas will be greatly apreciated!
Old 20-11-12, 04:54 PM   #2
savage86
Default Re: Condasation inside a headlight
don't know if it would be feasible to do inside a motorbike headlight but in my old skyline always had the same problem so i used the little bag of silica gel from a shoe it did the trick.
Old 20-11-12, 06:17 PM   #3
Fallout
Fallout's Avatar
haha. I had a skyline too! Rear light always got condensated. I took the whole cluster out, dried everything out with a heat gun and then sealed it up good and proper with Dum dum sealant.
MotoGoLoco - You knows it
Fallout Breakbeat (My Music)
Old 20-11-12, 06:46 PM   #4
Spank86
The thing about a hair dryer is it won't be guaranteed to effectively dry in a confined space, what you wind up with is hot humid air inside the cluster which can return to moisture and liquid when it gets colder.
Desiccant packs are the way to go to dry it out at the start.
Old 20-11-12, 06:46 PM   #5
savage86
It was the front headlight with me
Wish i had never sold it the dam thing
Old 20-11-12, 06:47 PM   #6
lights have to 'breathe' if they don't then they will mist up. condensation will only burn off if given enough time to do so so short trips will just make matters worse.
sealing them up is bad as there is nowhere for the heat to escape.
Old 20-11-12, 07:08 PM   #7
alfa.rbt
Thanks for input everyone
condensation in clocks gerrymcghee SV Talk, Tuning & Tweaking 2 14-12-09 11:01 PM
Should headlights (Daytona) get condensation in them? monkey Bikes - Talk & Issues 7 15-10-07 07:36 PM
Single headlight to dual headlight swap Jase22 Bikes - Talk & Issues 2 23-06-06 11:19 AM
New can fitted, water or condensation? kciN SV Talk, Tuning & Tweaking 11 23-03-06 05:27 AM
Condensation In Lights Ollie SV Talk, Tuning & Tweaking 5 11-11-05 04:06 PM
