Old 23-11-12, 03:45 PM   #1
MarkB852
Default Paint stripper for steel and alloy parts?
My project z750 has a frame painted a sickly shade of metallic green. That will be blown over no problem but the previous owner who perpetrated the frame paint has had enough left over to paint random bolt heads, washers, ancilliary tin work and even the master cylinder cover.
Can anyone recommend a good paint stripper that won't destroy the underlying metalwork? The steel bolts will probably live okay but I'm really concerned about the alloy master cylinder cover.
Thanks,
Mark
Old 24-11-12, 05:18 PM   #2
Default Re: Paint stripper for steel and alloy parts
For small jobs like that brake fluid works quite well as paint stripper.
Old 24-11-12, 06:29 PM   #3
Default Re: Paint stripper for steel and alloy parts?
I've used nitromorse on the sv wheel rims and forks. Found Blackfriars paint remover far better, as its self neutralizing. It didn't hurt either of those items.
If that helps any?
Old 26-11-12, 10:26 AM   #4
MarkB852
If that helps any?
Thanks for the replies. I'll try the Blackfriars although I can see the point of trying brake fluid too. It seems to have taken the paint off the calipers quite efficiently!
Thanks,
Mark
Old 26-11-12, 04:26 PM   #5
Sir Trev
Sir Trev's Avatar
Have also used Nitromors in the past on ally. As long as you neutralise it with plenty of water it was fine. Getting a decent lacquer coat on the casings once I'd polished out the grey crud was a lot harder!
swap my pointy alloy subframe for your steel one. leebex Stuff Wanted 5 16-01-12 12:21 PM
anyone want to swap their steel pointy rear subframe for my alloy one leebex The Essex Lounge 0 15-12-11 05:26 PM
paint stripper for plasatic panels? littleoldman Bikes - Talk & Issues 10 09-05-11 09:25 AM
Guess who's just realised that paint stripper on plastic panels isn't a good idea? monkey Bikes - Talk & Issues 8 11-05-08 06:37 PM
Difference Between Alloy & Stainless steel (Exhaust cans) G Exhausts 2 26-05-07 03:27 PM
