Old 26-11-12, 06:58 PM   #1
sv_rory
Default throttle & brake queiries
Ok ,
basically im going through the process of building a stunt moped to practice on and hopefully compete eventually.
what I would like to do is run a dual throttle so ive got one on each side of the bars.
I would like them to run opposite to each other so right hand side pull back and the left push forward. How easy would that be to do?
also I would like to run dual brake levers so have front and rear brakes both sides, how could i do this? Would I need 4 master cylinders?
thanks in advance
Old 26-11-12, 08:15 PM   #2
Default Re: throttle & brake queiries
For the throttle just use a second twist grip on the left bar if it's a typical throttle once fitted on the other side it will go backwards anyway, so to speak. You'll need a splitter like the one a Curvy has on the the choke cable.
There is a master cylinder that's fitted to a Honda scooter, (I forget which one, I'll have a think about that), it fits on one bar and works in the normal manner, and the other lever works a cable operated rear brake with a branch that also pulls the first master cylinder. Obviously you wouldn't need the branch off to the rear, but the master cylinder works from both levers - perhaps could be of use to you?
Changing throttle: twist to thumb push throttle? Joe Marcon Bikes - Talk & Issues 16 30-05-12 11:38 AM
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Frozen Throttle & Front Brake. krhall Bikes - Talk & Issues 19 24-12-10 05:59 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
Throttle / Revs sticking (and now brake question) goof SV Talk, Tuning & Tweaking 15 12-06-06 09:54 AM
