Old 02-12-12, 04:39 PM   #1
Sam_Skippy
Default Stripped sump plug threads.
Hi, I know im new to the forum but im having a major crisis!
Changing my oil this morning and somehow managed to strip the threads in my sump. I've managed to use Grandville Instant Gasket to temporarily fix it and its holding really well however I need a new Sump as a permanent fix. Does anyone know where I can get one?!?! Please and thank you?!!!
Thanks,
Sam
Old 02-12-12, 04:58 PM   #2
Geodude
Geodude's Avatar
Default Re: HELP! -- Stripped Threads in my Sump!
What bike? On my curvy its part of the engine block so cant just replace sump. Helicoil?
Old 02-12-12, 05:48 PM   #3
Sam_Skippy
Its the Pointy SV650 on a 06 Reg :/
Old 02-12-12, 05:51 PM   #4
You may get away with re tapping the threads and getting a new sump plug.
Old 02-12-12, 05:55 PM   #5
Get it to a mechanic and get them to check.
Might need a helicoil or timesert put in
Old 02-12-12, 05:56 PM   #6
Sam_Skippy
I've already tried re-tapping the threads and putting a new bolt in but its not working. I think I might have to get an M12 Helicoil Repair Kit and see if that works, the only downside is getting all the swarf and metal shavings out of the sump after I repair the threads. :/
Old 02-12-12, 06:15 PM   #7
Either drain oil again (preferred option) or magnetise sump plug if it isn't already.
You could drill/tap and plug it then re tap it correct size.
Old 02-12-12, 08:22 PM   #8
Default Re: HELP! -- Stripped Threads in my Sump.
There's no separate sump, it will need to be repaired. It would be best to tap it oversize as the case is thin and inserts often comes out with the plug which wears the new sump thread. I think the last one I fixed I used an M14 plug from a Ford*.
*Possibly, I can't remember exactly.
Old 02-12-12, 10:39 PM   #9
Sam_Skippy
Default Re: Stripped sump plug threads.
Okay cheers guys! Thanks for all the help, nice to be part of a forum I can get decent friendly bike advice from!
Old 02-12-12, 10:57 PM   #10
PS. The more I think about it the less certain I am it was a Ford plug, it was definitely a car plug though, but anyway the SV1000 uses an M14x1.25 sump plug which would work.
Oil Drain Plug - Thread Stripped Terah SV Talk, Tuning & Tweaking 35 28-05-12 12:45 PM
Spark plug as sump plug? Nobbylad SV Talk, Tuning & Tweaking 25 21-02-11 12:45 PM
HELP PLEASE - Oil Drain Plug Thread Stripped cbay SV Talk, Tuning & Tweaking 53 11-10-10 08:23 PM
Sump plug and stripped casing thread. mysteryjimbo SV Talk, Tuning & Tweaking 11 12-06-05 12:17 PM
