Old 04-12-12, 04:45 PM   #1
JonGeorge
Default Rear sprocket movement.
Hi,
I have a bit of movement in my rear sprocket, am I right in thing its the cushdrive rubber? It also coincides with poor gear changes.
Old 04-12-12, 06:41 PM   #2
muzikill
muzikill's Avatar
Movement as in loose which direction?
Old 05-12-12, 11:18 AM   #3
JonGeorge
Default Re: Rear sprocket movement.
I can move it slighty towards me and back towards the hub again.
Old 05-12-12, 11:49 AM   #4
Sir Trev
Sir Trev's Avatar
You mean in-out? Check to make sure your spacers are in properly (or missing).
Old 05-12-12, 12:03 PM   #5
Should check axle and sprocket bolts are tight. Rubbers do not do anything in this axis.
Has back end been disassembled recently?
Old 05-12-12, 12:14 PM   #6
JonGeorge
Ok will do, and no, the rear hasn't been touched at all?
Old 05-12-12, 12:36 PM   #7
-Ralph-
Is this a pointy or a curvy?
Check everything is there that should be there per these diagrams
http://www.ronayersmotorcycles.com/f...1999&fveh=2175
http://www.ronayersmotorcycles.com/f...003&fveh=10157
And check your rear axle nut and rear sprocket nuts are torqued correctly (60nm and 100nm).
Old 05-12-12, 12:38 PM   #8
And it should go without saying but don't ride it until you've sussed this as some of these possibilities have significant chance of causing damage to bike and/or falling off.
Old 05-12-12, 12:39 PM   #9
-Ralph-
That means you falling off, not just bits from the bike.
Old 05-12-12, 12:46 PM   #10
muzikill
muzikill's Avatar
Id say if the there was a spacer worn or missing and the sprocket hub/carrier was loose then the wheel would have play in it. If not then the sprocket mounting nuts must be loose?
Standard front sprocket, bigger rear sprocket, how many more links in chain required? Holdup Bikes - Talk & Issues 6 27-02-12 12:40 PM
Rough movement of rear brake pedal. Chris Bird Bikes - Talk & Issues 9 13-08-11 01:00 PM
Rear sprocket, which way? DavieSV SV Talk, Tuning & Tweaking 0 12-05-08 10:40 PM
REAR SPROCKET? nikki_sv400s SV Ecosse 4 31-08-06 05:11 PM
47T Rear Sprocket bobit69 SV Talk, Tuning & Tweaking 39 26-03-06 10:53 AM
