Old 05-12-12, 11:35 AM   #1
650
650's Avatar
Default Wiring heated grips?
Morning all
I have heated grips on my bike which I'm yet to wire up (definitely doing it now, even my Held Freezer gloves succumbed to the bitter cold this morning!) and I'm wondering if there's a set way to use a relay so they only work once the ignition is on. I don't want to risk draining the battery overnight by either accidentally leaving them on or there being an issue with them draining even when turned off.
Any help will be muchos appreciated
650 is offline   Reply With Quote
Old 05-12-12, 12:07 PM   #2
saucysaunders
Default Re: Heated grips
Look at the fuse box, there is a spare terminal on the far right hand side, use this.
Remember to put a fuse in so that it works as well obviously.
Or, buy one of these once they are made...
http://forums.sv650.org/showthread.php?t=187590
Old 05-12-12, 12:29 PM   #3
650
650's Avatar
I'm completely inept at anything electronics...
So would I be putting a fuse in there and wiring the grips to that? Apologies if that sounds absolutely retarded haha
Old 05-12-12, 12:45 PM   #4
saucysaunders
This explains in full
http://forums.sv650.org/showthread.p...=fitting+grips
Old 05-12-12, 01:09 PM   #5
650
650's Avatar
Ah brilliant, looks a doddle...especially as they're already fitted. Will just need some extra wire and some bullet connectors. Thanks for the link
Heated grips wiring path along the bike? Fluffer SV Talk, Tuning & Tweaking 0 05-12-11 01:37 PM
Heated grips £15 Jordy For Sale - Other Bikes and General biking items 0 05-09-10 09:29 PM
Oxford heated grips and symtec heated grips Alpinestarhero Ancillaries 18 25-01-10 04:43 PM
wiring up oxford heated grips hovis Bikes - Talk & Issues 23 07-11-07 08:01 PM
Heated Grips NAPA121 Bikes - Talk & Issues 7 12-09-05 09:38 PM
