Old 19-12-12, 12:23 AM   #1
Runako
Exclamation SV650S Bolt Chart / Size Guide
Project: To list as many nuts and bolt sizes/details for the SV650 (second Gen/faired).
Aim: Seeking to overhaul the SV and replace old stock stuff? Want to do research to avoid paying for overpriced bolts? (I.e. Pro-bolt)
Contributions: Welcome! If you want to add to the list (or correct anything here), please feel free to post.
Fastner Tools (Printable Guide) - Great Info on fastner types, heads & measurements.
Fastner Basics - Brief Guide covering purpose and usage
LIST
  • Location
  • Size (incl thread pitch where applicable)
  • Type / Code
  • Number
  • Torque
1. Front & Rear Discs
  • M8 x 22mm - 1.25mm pitch
  • SS/Ti: TIDISCSUZ20 /LSSDISCSUZ20
  • 5 per Disc
  • 23nm / 16.5lbft
2. Fork Axle Bottom Pinch Bolt (Flanged Hex)
  • M8 x 40mm - 1.25mm pitch
  • SS/Ti: LSSHX840 / TIHX840
  • 1
  • 23nm / 16.5lbft
3. Caliper Mounting Bolts (Flanged or other)
  • M10 x 25mm - 1.25mm pitch
  • SS / Ti - Flange 8.8 tensile min
  • 4 (2 per caliper)
  • 39nm / 28ftlb
4. Sprocket Nuts
  • M10 x 14mm - 1.25mm pitch
  • SS/Ti: SPN10B / T15SPN10
  • 5
  • 44nm / 33lbft
5. Sump Plug
  • M12 - 1.25mm pitch
  • SS/Ti: 8.8
  • 1
  • 21nm / 15lbft
6. Damper Rod
  • M8 x 25mm - 1.25mm pitch
  • SS/Ti: Stainless
  • 2 (1 per damper)
  • 30nm / 21.5lbft
7. R&G Engine Mount Bolt
  • (Left) M10 x 100mm - 1.25mm pitch
  • (Right) M10 x 150mm - 1.25mm pitch
  • SS/Ti: Hex Head Bolt with long shoulder
  • 1
  • 40nm (recommended by R&G but Manual is good)
8. Mirrors
9. Windscreen
10. Underseat
11. Nose Cone
12. Lower Fairing
13. Tail Fairing
14. Rearsets
15. Clip on
16. Upper Triple
17. Lower Triple
Old 03-03-15, 03:31 AM   #2
Runako
Default Re: SV650S Bolt Chart / Size Guide
Continuing this project. May be useful to anyone looking to replace bolts on the SV but there's some good info here which could apply to any bike. Feel free to contribute.
Old 03-03-15, 11:08 AM   #3
ophic
ophic's Avatar
As this is a reference thread, can we have it stickied?
Silver SV650SK3, Fuel exhaust
Old 03-03-15, 01:56 PM   #4
Seconded
Old 03-03-15, 04:05 PM   #5
Corny Gizmo
Thirded!
Old 03-03-15, 06:33 PM   #6
Runako
Nice one. Started with the intention of not having to rely on the usual reply of "buy it from Suzuki" or even worse Pro-bolt, which is far too expensive. There are many suppliers of suitable bolts out there with the main issue being people don't know the sizes & pitch. But if this info helps one person source a better deal, then job done.
I'm about to do a mini overhaul on the SV and purchased the full fairing bolt kit for £26 quid, so will be adding all fairing bolt and engine bolt sizes shortly. As above, please feel free to contribute to the info if you can.
Old 04-03-15, 01:05 PM   #7
wideguy
Useful information, but I've found fastener supply stores to have knowledgeable employees and the tools to correctly measure and match hardware, including strength and hardness (usually). Of course you need an example to take to them for matching...
A Google search by Suzuki part# usually works too, for example searching for 07130-08202 takes me right to a parts supplier where the bolt is identified as 8X20. Not always enough information, but a good start.
Old 04-03-15, 01:31 PM   #8
Runako
The problem is that some of us don't have that luxury of a good shop nearby. Others would like the online option (me) & your knowledge of these things is far greater than a newbie.
Why not drop some info in here though? Even if it's a link to some of those suppliers you mentioned. (Doh... You're in the US)
Old 05-03-15, 02:55 PM   #9
wideguy
Yes, sorry, but it does have some benefits. Everywhere I've lived in the U.S., there has been a place like the one I currently use, called Automotive Fasteners, that's both helpful and a good source of all sorts of fasteners, (except titanium). You do need to know if the fasteners you're looking to replace need to be high strength or not, corrosion resistant or not, etc. It's good to replace a fastener with a better one, but not good to downgrade. If there are grade markings on the fasteners you remove, that's good, they'll know what they mean. If unmarked, you can tell them what its used for, where it goes, but it's always up to you to get what you really need, not all countermen are experts.
Thread gauges and calipers, plus basic knowledge of fastener properties, which can be learned on the internet, make it possible to find and order what you need, but a machine specific list like yours Runako is just simple and easy.
Old 29-03-25, 05:28 PM   #10
garynortheast
garynortheast's Avatar
Zombie thread back from the dead! It would be useful to see if we can update this I think.
Blue Curvy S with over 110,000 miles and still going strong.
Rear sprocket bolt size on 2nd gen SV650S? Landshark SV Talk, Tuning & Tweaking 1 14-07-07 10:41 PM
Help with bolt size TC3 SV Talk, Tuning & Tweaking 2 20-03-07 06:28 AM
Bolt size TC3 SV Talk, Tuning & Tweaking 2 12-01-06 02:55 PM
HELP Bolt Size ... sprocket SV Talk, Tuning & Tweaking 2 02-07-05 08:11 PM
bolt size please Quiff Wichard SV Talk, Tuning & Tweaking 17 20-05-05 09:03 AM
