Old 23-12-12, 11:43 AM   #1
Robust2
Default Goodridge brake line length, faired/naked?
Hi all,
I bought myself a set of Goodridge braided hoses (2 piece, 'race' style) for my K6 SV650N as a christmas present and was really excited when they arrived on saturday. However, upon inspecting the package it said they were lines for a K3-K5 SV650S. I contacted the seller, who pointed out that these are the lines that Goodridge specifies for my bike in their catalogue: http://www.goodridge.net/documents/d...012_suzuki.pdf
I was always under the impression that the S brake lines are a bit shorter due to the clip ons and Goodridge has made a mistake? The K3 has different lines for the N and the S, which strengthens my belief.
Could anyone confirm this or does anyone have experience fitting the S lines onto their naked?
Old 23-12-12, 12:18 PM   #2
Default Re: Goodridge brake line length
yes they are to short if they are for an S.
Old 23-12-12, 05:51 PM   #3
Shawthing
Shawthing's Avatar
Yes . Looks like a Goodrich Typo but could be that they are made overly long.
Measure the length of the shortest of the two Goodrich lines ( center of banjo to center of banjo ). S Bike right caliper line will likely be between 73 and 76cm. N Bike line should be noticably longer.
Use the 'piece of string' method to measure , on the bike, the length of your current brake line from the center of banjo on your master cylinder down to center of banjo on you right ( as you sit on the bike) caliper.
This will tell you if they are going to be OK or not.
SK9 Sport Black Delkevic can.
Old 23-12-12, 07:07 PM   #4
Robust2
The shortest of the two Goodridge lines is 75mm. I measured my line on the bike with a tape measure and it's more around 80mm. Thanks for the help!
I'll contact Goodridge when they start working again after new year, as I don't feel like the seller should fix their faults.
Old 23-12-12, 10:04 PM   #5
no. seller sent wrong lines and nothing to do with goodridge so contact seller and either get refund or get them to send correct lines.
Old 24-12-12, 12:16 PM   #6
Shawthing
Shawthing's Avatar
No problem.
Do contact Goodridge, at same time as the seller, as thier datasheet does look wrong and putting short lines on a bike has possible serious consequences.
Old 24-12-12, 02:10 PM   #7
Robust2
Seller sent the lines Goodridge told him to send for my bike. As Shawting said, it can only help future buyers as well.
Hel brake line kit saved by Goodridge part Daywalker SV Talk, Tuning & Tweaking 5 02-05-10 07:35 PM
Brake line length Naked K3? barwel1992 SV Talk, Tuning & Tweaking 12 15-03-10 10:52 AM
Rear Brake hose length - Naked vs Faired DarrenSV650S SV Talk, Tuning & Tweaking 4 11-03-09 08:15 PM
Hel Brake Line Length Biker_Billy SV Talk, Tuning & Tweaking 7 27-03-08 10:33 PM
Goodridge rear brake line Bez SV Talk, Tuning & Tweaking 1 15-01-06 04:58 PM
