Old 02-01-13, 12:18 PM   #1
M65
Default Rear brake hose length after shock swap?
Im going to be swapping the OEM shock to a ZZR1400 one fairly soon and while Im at it, I thought I would replace the standard rubber brake hose at the back.
I have heard that you need a longer hose if you do this shock swap. Is that the case? If so, what is the length of the standard hose please and how much longer must a new one be to cope with the slightly taller shock?
Many thanks
Old 02-01-13, 12:32 PM   #2
Default Re: Rear Brake Hose After Shock Swap
what bike is it for?
Old 02-01-13, 12:33 PM   #3
Not that I know of
Old 02-01-13, 12:47 PM   #4
M65
Sorry. Its a K3 650 (pointy)
Old 02-01-13, 12:56 PM   #5
as Y_C says it wont need to be any longer and aftermarket ones usually come slightly overlong anyway. it's the routing of the line that people mess up so think they need a longer line.
Old 02-01-13, 06:46 PM   #6
joshwalker094
joshwalker094's Avatar
Not that I know of
Chris is right, he swapped my shock over to a zx10r which is longer, and my braided hose Is fine
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 03-01-13, 08:34 AM   #7
M65
Cheers guys, thanks for the info. I guess a normal braided hose kit will do the job then.
Goodridge rear hose length & guarantee test? muzikill SV Talk, Tuning & Tweaking 32 20-03-12 10:09 PM
Rear pre-load and shock length question DavieSV SV Talk, Tuning & Tweaking 1 14-06-10 08:46 AM
Rear Brake hose length - Naked vs Faired DarrenSV650S SV Talk, Tuning & Tweaking 4 11-03-09 08:15 PM
Rear Brake hose svdemon SV Talk, Tuning & Tweaking 8 19-08-08 10:37 PM
Brake hose length, pointy vs curvy 2pc race kit Tim in Belgium SV Talk, Tuning & Tweaking 7 20-02-08 04:20 PM
